Trailex trailers?
What do we know about Trailex trailers? I take it since they bolt together, they need routine maintenance for tightening nuts and bolts. I’m looking at one in Ohio and it’s a hike but it’s only $3500. It looks like an older model and does not have the long ramps I’ve seen on others.
See the ad. https://www.racingjunk.com/open-car-trailers/184384688/aluminum-trailex-19-tandem-axle-car-trailer.html Thoughts? Is it worth $3500? Anybody nearby to take a look? ![]() ![]() Last edited by A930Rocket; 11-04-2022 at 05:22 AM.. |
Or plan B. Much closer, all steel, wood deck, etc. $3650
https://charleston.craigslist.org/tro/d/hartsville-brand-new-82x18-ft-dovetail/7551815979.html ![]() ![]() Last edited by A930Rocket; 11-04-2022 at 05:22 AM.. |
The steel with wood deck is a more versatile trailer. I have a 16' steel with wood deck and I added 18" wood sides that I can put on and off into the stake pockets. Great for hauling firewood and mulch, as well as moving boxes. Plus if it ever cracks or breaks, you can just weld it back together! Only thing is, all your friends will want to barrow it.
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
Platinum Member
I've never seen a trailex with curved frame before, and I've seen them at the track since 1992. Age is glaringly absent from the ad.
I had a trailex with tire rack and pull out ramps. Traded it for a solid deck aluminum trailer, much more versatile if you want to carry anything other than a car. (lumber yard run, pick up furniture, etc.) What car are you carrying, and what is the tow vehicle?
Politics is in the eye of the beholder - Rodney Dangerfield |
The only thing I disliked about my Trailex was the relatively high deck height, which necessitated very long ramps on my very low track car, never had an issue w/ loose bolts, did have keep after the wiring and lights a lot, having a storage bin for stuff is big
When towing lighter is better especially when you get in the hills
I’ll be towing my BMW 330, which weighs about 2800 pounds. My truck is a 2014 F150 with the 5.0 and tow package. 2WD.
I emailed the trailex owner and it’s at least a 2001 and probably older. Talking to a few people, they mentioned metal fatigue where the springs/torsion bars are attached to the frame. One thing is, I’d like to keep the trailer as short as possible for my car and possibly Ms. Rockets 2010 Tahoe, in case it breaks down. I need to price out storage as well, as I don’t have room for it. |
I think I've said this before, Trailex are fine trailers but they are single function. YMMV but I've always had to tow all kinds of stuff other than cars making a deck trailer a better choice for me.
As dad says above, never seen a curved version.
Tru6 Restoration & Design |
Behind the Sun
I've had a couple of trailex
I've seen hundreds of trailex That example by OP has been hacked. Lots of things that don't match. I wouldn't go look at that one. Something is not right |
Thanks, guys. Yeah, it looks a little run down and definitely an older model. A cheap trailer is an expensive trailer by the time I get it up to par.
Just called a storage place and it’s $100 a month to store a trailer uncovered. Ouch!
Maybe it’s better to rent a U-Haul trailer. |
Are you a member of the moose or is this a lodge near you?
They typically have RV spots and trailer storage. I keep a couple of mine at the Moose lodge, plus you can get a good lunch and cheap drinks. ![]() Back to topic, I too have owned a Trailex or two in the past. They are a big Erector Set, simple, lightweight and easy to move around. But for the same reasons listed above, I have moved to Featherlite trailers. That being said, there is one sitting not far from me, but I have not been able catch the owner yet, and if cheap enough or the right trade, I will grab it. One positive thing about the open bottom is that you can work on the bottom of your car. ![]()
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
lastly the older trailers tended to have narrower deck space my '72 w/ Carrera flairs barely fit on one of the older Trailex models
My current RV is based on the MBZ Sprinter chassis and towing is limited to 5k with a GVWR putting it closer to 4500#. A light weight aluminum trailer might be just the ticket as 1100lb trailer, car, tire rack, tool box come in at about 4500#. I am keeping my eye open for a featherlight in the area but most want $8k for them used. A Steel deck trailer is typically 2000# and that would certainly put me overweight.
I do have a friend nearby with acreage who said I could leave the trailer at his place which is super convenient.
2009 Cayman PDK With a few tweaks |
No moose lodges that I know of. I need to keep looking around and also, see who I know.
https://www.mooseintl.org/programs-events/ https://m.facebook.com/156187807746296/
An aluminum trailer has many benefits , the biggest being lighter in weight . This is important when your tow vehicle is less than ideal . Remember when fully loaded you have to be able to accelerate and brake safely . And be able to handle panic stop or evasive manuevers .
I have owned an aluminum car trailer in the past but my current trailer is a 16' steel deck metal frame . Rated at 7000 lbs when you subtract the 2000 lb weight I can safely tow 5k . More than heavy enough for me . My tow vehicle is an extended cab one ton dually diesel so plenty of safety margin . |
As others have noted, that Trailex does not look much like my 2002 CT7541 in the front. Mine is all angular.
Commenting on the size discussion... There were two models that were often used for 911s. IIRC, the larger one was CT7041 (which became the CT7541 then the CT7551). There was also a 7031 which looked the same but was smaller. You could barely squeeze a midyear on those (if I recall). Best for an MG or maybe a long hood...but later cars would really not fit. Some of these were reengineered (modified) by their owners to accommodate slightly larger cars. Trailex still sells parts for the CT 7031 but I am not sure they sell the trailer anymore. Most folks want the "midsize" CT7551 if possible which measures: Overall Length: 19'5" Overall Width: 8'4" *Bed Length: 12'9" Fender Height: 6-1/4" Width between Fenders: 75" **Center Opening: 42" Weight Capacity: 5100lbs.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
There’s a bunch of these trailers selling for about $2500. Same ones that U-Haul has. They’re almost 2000 pounds!
Last time I rented one, 15+ years ago, I noticed they use a 15 1/2 inch wheel. This was so people would not steal the wheel/tires. ![]() This one is local, $1500, but looks a little rough. ![]() |
Uhaul trailers are heavy heifers.
More utility on the trailer from post 2.
dolor et pavor Copyright |
Thread Tools | |
Rate This Thread | |
