Evil Genius
Rusty Heap's Avatar
Behold the Power of Ice
Springtime ritual I do every year is drain and fill the Hot Tub with a change of water.
Hint Hint: It got down to 17-20F for about a week during last winter.
Went to use my cast iron transfer pump and got a free shower and shoe washing.
Don't know the wall thickness of the cast iron material, but it had an 8" long crack going around 3/4 of the base with deformation up to 1/8".
JB Weld to the rescue. Looking forward to next winter, bring it on......
Yes it was a Harbor Freight unit. But still?
Behold the Power of Ice.
Life is a big ocean to swim in.
Wag more, bark less.
Old 03-05-2024, 10:49 AM
weekend wOrrier
Only use Harbor Freight epoxy on Harbor Freight products
Old 03-05-2024, 11:15 AM
Edministrator
Steve Carlton's Avatar
Water expands when it freezes and it’s going to have its way.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Bland
unclebilly's Avatar
This is why we winterize everything.. RV plumbing, boats (manifolds split all the time), cabins, etc.
Its a thing.
Old 03-05-2024, 11:16 AM
I see you
flatbutt's Avatar
Precisely why we can't freeze and successfully thaw living creatures.
Old 03-05-2024, 11:34 AM
Edministrator
It’s a very unusual property of water that has a profound effect on life on earth.
https://www.e-education.psu.edu/earth111/node/842#:~:text=Water%20expands%20when%20it%20freezes, in%20a%20glass%20of%20water).
O - $1
O - $2
O - $3
Old 03-05-2024, 11:35 AM
MBAtarga's Avatar
I just use suction from two old garden hoses I've cut down in length to drain our tub. Just immerse them from one end at a time and slowly feed them until the other end is under water, then cover the opening with your palm and lift it out and down to the ground. Nature and physics will do it's job.
Mark
'83 SC Targa - since 5/5/2001
Old 03-05-2024, 12:28 PM
I remember seeing a science show about the power of ice. They built thick steel blocks, bolted together win large bolts, and the ice just broke them. The power of freezing water is just amazing.
Old 03-06-2024, 07:24 AM
fastfredracing's Avatar
I have seen engine blocks, cracked up from the crank up to to the deck and follow right up into the cylinder head . Big block chevy , the freeze plugs did not save it .
Also saw a 305 fracture in the same way .
No left turn un stoned
Old 03-06-2024, 07:38 AM
Banned
Expansion is the super power of ice!
but, about those frozen embryos...
Old 03-06-2024, 07:39 AM
... The power of freezing water is just amazing.
The unfrozen stuff ain't too shabby either .... H2O will always win .... the Grand Canyon, Yosemite Valley .... it doesn't play nice with others .... always getting it's way!
Old 03-06-2024, 07:58 AM
Model Citizen
herr_oberst's Avatar
Irrigation tubes in every furrow is how my grandpa used to water the crops. He was good at it; it takes skill to do it quickly, necessity creates the skill.
Old 03-06-2024, 10:24 AM
Counterclockwise?
Can't stop the ice either
Rod
1986 Carrera
2001 996TT
Old 03-06-2024, 12:02 PM
Old 03-06-2024, 01:58 PM
I see you
flatbutt's Avatar
Then there is "Mizu no Kokoro":
https://www.trans4mind.com/counterpoint/index-esoteric/cooper3.html#:~:text=It%20is%20neutral%20and%20is% 20unable,events%20and%20the%20stresses%20of%20life .&text=It%20is%20neutral%20and,the%20stresses%20of%2 0life.&text=neutral%20and%20is%20unable,events%20and%20th e%20stresses
Old 03-07-2024, 05:18 AM
Fleabit peanut monkey
Bob Kontak's Avatar
When I have these kinds of ice damage issues Igloo it back together.
1981 911SC Targa
Old 03-07-2024, 06:23 AM
Edministrator
O - $1
O - $2
O - $3
Old 03-07-2024, 06:39 AM
