Evil Genius
Behold the Power of Ice
Springtime ritual I do every year is drain and fill the Hot Tub with a change of water.
Hint Hint: It got down to 17-20F for about a week during last winter. Went to use my cast iron transfer pump and got a free shower and shoe washing. ![]() Don't know the wall thickness of the cast iron material, but it had an 8" long crack going around 3/4 of the base with deformation up to 1/8". ![]() JB Weld to the rescue. Looking forward to next winter, bring it on...... Yes it was a Harbor Freight unit. But still?Behold the Power of Ice. ![]() ![]()
Life is a big ocean to swim in. Wag more, bark less.
weekend wOrrier
Only use Harbor Freight epoxy on Harbor Freight products
100% narcissist |
Edministrator
Water expands when it freezes and it’s going to have its way.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Bland
This is why we winterize everything.. RV plumbing, boats (manifolds split all the time), cabins, etc.
Its a thing.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I see you
Precisely why we can't freeze and successfully thaw living creatures.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Edministrator
It’s a very unusual property of water that has a profound effect on life on earth.
https://www.e-education.psu.edu/earth111/node/842#:~:text=Water%20expands%20when%20it%20freezes, in%20a%20glass%20of%20water).
I just use suction from two old garden hoses I've cut down in length to drain our tub. Just immerse them from one end at a time and slowly feed them until the other end is under water, then cover the opening with your palm and lift it out and down to the ground. Nature and physics will do it's job.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I remember seeing a science show about the power of ice. They built thick steel blocks, bolted together win large bolts, and the ice just broke them. The power of freezing water is just amazing.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I have seen engine blocks, cracked up from the crank up to to the deck and follow right up into the cylinder head . Big block chevy , the freeze plugs did not save it .
Also saw a 305 fracture in the same way .
No left turn un stoned |
FUSHIGI
Expansion is the super power of ice!
but, about those frozen embryos...
Cults require delusions. |
Model Citizen
Irrigation tubes in every furrow is how my grandpa used to water the crops. He was good at it; it takes skill to do it quickly, necessity creates the skill.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Counterclockwise?
Can't stop the ice either
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I see you
Then there is "Mizu no Kokoro":
https://www.trans4mind.com/counterpoint/index-esoteric/cooper3.html#:~:text=It%20is%20neutral%20and%20is% 20unable,events%20and%20the%20stresses%20of%20life .&text=It%20is%20neutral%20and,the%20stresses%20of%2 0life.&text=neutral%20and%20is%20unable,events%20and%20th e%20stresses
Fleabit peanut monkey
When I have these kinds of ice damage issues Igloo it back together.
1981 911SC Targa |
Edministrator
