While I was tracking an oil leak that was pooling on the heat exchangers I took a piece of metal and Jb welded a ramp so the oil would drip off the exchanger and not pool. The jb weld held until I found the leak (rocker shaft seals fixed it) and I had to chisel it of, there are still remnants there on the top of the exchanger.
So on the outer part of the exchanger it will definitely hold.
Old 04-04-2007, 04:18 PM
Hell Belcho
Nostril Cheese's Avatar
Originally posted by msk1986911
I've got what appear to be the start of some rust holes on the heat exchangers on my '86 911. Would JB Weld be a suitable repair after I get rid of the rust? Would it stand up to the heat? A previous comment on this thread seems to imply that it would not; just thought I'd ask the question directly.
I have used it on a rusty 911 muffler and 914 heat exchangers with good results. The key is prep. Clean bare metal.
Old 04-04-2007, 04:58 PM
B58/732
BlueSkyJaunte's Avatar
Clean bare metal but make sure it isn't shiny! It helps to have some "scuff" to bond to.
ΜΟΛΩΝ ΛΑΒΕ
Old 04-04-2007, 05:48 PM
techweenie's Avatar
Originally posted by mikester
the JB weld lobby is the strongest lobby ever.
ROTFLMAO!
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 04-04-2007, 06:08 PM
mikester's Avatar
Send a message via AIM to mikester
Originally posted by techweenie
ROTFLMAO!
Yeah, probably the funniest thing I've ever said.
How sad.
-The Mikester
I heart Boobies
Old 04-04-2007, 06:24 PM
AFJuvat's Avatar
http://jbweld.net/faq.php#faq002
From that site:
Q: Is J-B Weld toxic?
A: No. J-B Weld is non-toxic. However, we do not recommend consuming the product.
Who would even think of eating it?
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-05-2007, 03:28 AM
Parrothead member
VINMAN's Avatar
Its pretty good on an english muffin.
Vinny
Old 04-05-2007, 04:05 AM
Thanks for the link Mikester:
Q: Will J-B Weld work on an automotive exhaust?
A: Because of the extreme temperatures of exhaust systems, we do not recommend J-B Weld for use on exhaust manifolds and catalytic converters. Nor do we recommend the product for repairs within the combustion chamber.
Old 04-05-2007, 04:15 AM
Parrothead member
VINMAN's Avatar
I have tried it on cast iron exhaust manifolds, it usually shrinks and cracks off. But have had great results on water-jacketed marine manifolds.
Vinny
Old 04-05-2007, 04:19 AM
David's Avatar
It's been plugging a hole in my truck's oil pan for a couple years now. Maybe I should put the story in the stupidest things you done thread .
Old 04-05-2007, 04:20 AM
Parrothead member
VINMAN's Avatar
+1
4 yrs and holding strong!
Vinny
Old 04-05-2007, 04:25 AM
cycling has-been
bkreigsr's Avatar
excellent for gluing spacers, reel seats, and cork to a rod blank. slow set-up time gives you time to maneuver anything mis-aligned
(go fish)
Bill K
Old 04-05-2007, 06:15 AM
TSNAPCRACKLEPOP's Avatar
used it on a water pump in a home water system, held forever, and a radiator drain plug. clean, dry surface, the slow setting stuff, and a heat lamp. 24 hours before use of the repaired item.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 04-05-2007, 06:45 AM
Probably better than this stuff
Warren & Ron, may you rest in Peace.
Old 04-05-2007, 07:05 AM
the vegamite sandwhich!
Old 04-05-2007, 07:07 AM
The Unsettler
stomachmonkey's Avatar
Apologies to our Aussie brethren but Vegemite is some nasty stuff. Peanut butter it ain't.
"I want my two dollars"
"Brandon Won"
Old 04-05-2007, 07:14 AM
I have patched motorcycle engine cases with JB and never had it fail yet. Amazing stuff.
Randy
'87 911 Targa
'17 Macan GTS
Old 04-05-2007, 01:44 PM
Senior Member
Years ago, circa 1978 or so was driving up in Northern part of Missouri on a country road. All of a sudden lots of blue smoke out of the back so I stopped.
I had picked up a bolt with one of my front tires and somehow thrown it into my oil pan. No idea where it came from, but it was not from my car. Found it lodged in the side of the aluminum oil pan, with oil dripping out near the exhaust manifolds. Limped the car into a nearby garage and we put it up on the lift. Not many Jaguar oil pans in that neck of the woods.
We cleaned it off with spray brake cleaner and sealed it up with JB weld and let it sit for lunch. Re-filled it with oil and headed home.
That repair lasted for almost 30 years until I restored the car two years ago. Found the repair and smiled at its lasting that long. The oil pan is retired now and a serviceable unit in its place.
Done correctly JB weld will do almost anything and last a long time.
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 04-05-2007, 03:41 PM
rnln's Avatar
let me take a chance. So, JB weld can't stand the heat as hot as exhaust manifolds. Is there any similar product which can, beside real welding?
Fat butt 911, 1987
Old 06-30-2017, 01:04 AM
My wife's uncle was a tractor repair mechanic. He said on a regular basis he had tractors come in for a complete engine rebuild and would find repairs done to an engine block done with JB Weld. He said if it was an area that was cost effective to weld up they fixed it right. Sometimes they just left it alone at the farmers request. He saw some interesting repairs done by farmers trying to get the crops in.
Old 06-30-2017, 05:42 AM
