This puts raw acceleration into perspective!
Good read but the last paragraph is the best and one that some of us could slightly begin to comprehend the sheer power of these beasts...
REAL “ACCELERATION" One top fuel dragster with 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500. (approx - 8000 hp) Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second. A fully-loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger. With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, (very rich) the flame front temperature measures 7,050 deg F. (air/fuel stoichiometric is approx - 14.7:1 on a car) Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. Dual magnetos supply 44 peak amps to each spark plug. This is essentially the output of an arc welder in each cylinder. Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow. If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's. Dragsters reach over 300 miles per hour before you have completed reading this sentence. Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load. The redline is actually quite high at 9,500 rpm. Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second. The current top fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta). You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The "tree" goes green for both of you at that moment. The draster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it; from a standing start, the dragster had spotted you 200 mph and not only caught you, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course. That, folks, is acceleration )
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Makes my 911 seem slow (not feel, just seem)
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Yeah, but if those dragster guys have to turn left or right they crash!
So actually they couldn't beat me thru a sub-division if I was driving a Honda Civic.
The raw power of top fuel drag racing is so over the top that it's hard to believe that's it's even possible to harness that amount of energy. Technically, it's an interesting sport but watching is so boring in my opinion. I occationally can sit through short highlights but nothing more.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
When I was in high school in the fifties dragsters were turning a 132 MPH, they said at that time 150 MPH was the mathematical maximum a car could accelerate in a quarter mile. I don't know if that is true or not, but they've sure beat that by a long ways. By any stretch of the imagination it's big business...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Great read. Just incredible. Thx.
87 blk coupe |
And that's on 90% nitro. They used to run 98%. Where's the limit now? When will they reach 350 MPH and that many more G's? Already one top fueler retired because of stress on the eyes due to the G's (Joe Amato with detached retinas). So far, he's the only one to admit physical problems.
Detached Member
Watching on TV is nothing compared to being there. If you've never been you should definitely go. The pressure wave that passes through you is like nothing you've ever experienced.
Hugh |
I was at the season ending event in Fontana. I had a full media pass with the blue vest so I could go wherever I wanted.
I took my camera and set up on about eight feet from where the Top Fuel launched. On the first pass as the car left it scared me so much that i ducked behind the concrete wall and covered my head. When I finally looked up everyone in the stands as well as all the other Proffessional Photographers where laughing their a$$es off of at me. I was quite an experience. If I can get my other computer fixed I will post some pictures I took from the start line. Like so many things, TV can not do it justice. Steve
1982 SC |
That text has been around for years. It's a viral that I think originally appeared in a somewhat different form in Car and Driver about 10 years ago.
But have you seen the urban-legend e-mail about what your fuel-gauge pump icon _really_ means???
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Everything there looks correct except the 8 G accel number. The theoretical limit of 150 MPH was based on a friction coefficient of 1 I believe. Since modern tire technology can exceed that and since the car has a wing for downforce the limit is much higher. It's likely that the coefficient of friction is around 3 based on the performance of the car. This means at launch it can pull 3 G's. As the speed increases and the wing starts to push down on the car the G can increase. The max G is probably in the middle of the run somewhere and would be above the average of 4.5 G. A good guess would be around 6 G and would require the downforce to be twice the car weight at whatever speed this occurs.
-Andy
72 Carrera RS replica, Spec 911 racer |
JW Apostate
When they run at Sonoma, I can hear them from my house in Napa, 15 miles away.
KT
'74 914-6 2.6 SS #746 '01 Boxster |
Slackerous Maximus
They missed one:
Top fuel dragster = 8000HP Combined tooth count of all drag racing fans in USA = 7325 .....just pulling your chain, good read! Some amazing engineering going on.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
They are impressive either way you add it up. Some of the numbers in this latest version do not add up, granted, and there are some other "enhancements" made as well. Still, the real numbers are impressive enough. No need to exagerate with these cars. "Naught to 330" in just over four and one half seconds ain't bad.
I actually had the chance to wrench a little bit on a funny car back in the early '80's, back when they still had the full class deignation of "AA/FC". Strictly "amateur hour", this was a group of knuckleheads off the shop floor that would run one whenever they could pull together enough spare change to make it run. They did manage the track record in Denver one year, but that was their only claim to fame. This was when the NHRA still had enough local yokels running these things to actually give divisional points in the fuel classes. Before it got "expensive", relatively speaking. Back when they sometimes still had 32 car fields at nationals. But I digress... These cars won't "diesel". They were just starting to run dual mags and dual plugs back then, but for different reasons than we do. It was (still is) for the redundancy; just like an airplane. It's pretty common to lose a plug on a run, and the second one gives it a chance to keep firing on that cylinder. If you lose both plugs, it drops that cylinder. You can actually see when a car does this; the exhaust pipe on that cylinder starts looking like a sprinkler. It just keeps pumping the raw fuel through it. The part about shutting off fuel flow to cut the engine is kinda sorta true. Problem is, the driver cannot do it. The NHRA does not allow fuel control valves, nor levers to control them, in the cockpit for safety reasons. The motors run on mags and again, there is no driver accesible shut off. A crew member has to shut the car off. In the case of an aborted run, keep your eyes on the guy that walks up and shuts it off. At the end of the run, it just runs out of fuel somewhere in the shutdown area. You will see these cars wreck sometimes and rather inexplicably (seemingly) just keep running. I saw a top fuel car flop on its side after getting crossed up right out of the hole one day; it kept spinning like a top around the rear tire that was on the ground. No way to stop it; the driver just had to wait for it to run out of gas. These machines are just so over the top they defy belief. They are now running eight gallon tanks on these cars (the guys I hung out with ran five) and they run them dry in one burnout and a single pass. The burnout uses just about a gallon of it. With that in mind, try filling an 7 gallon container in 4.5 seconds. See how many garden hoses running at full blast it takes to do that. That is the fuel flow into a nitro burning motor. The NHRA has now bumped the percent down once again in an effort to somewhat control these cars. I believe it is down to 85% now, with the rest methanol. Anyway, drag racing as a whole is pretty damn boring. I am, however, and will remain a lifelong fan of top fuel and funny car. If you have never seen one live, go do it. You owe it to yourself. Even if you hate drag racing and everything to do with it. You have my money back guarantee; you will never see anything else like it. TV does it no justice whatsoever.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I'm with Bill
This is the only way to put it in perspective.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Here in Charlotte Bruton Smith (owner of Lowe's Motor Speedway) just brought the city of Concord and its leaders to their knees by threating to move if they did not let him build a major NHRA track facility on his race track property. When the city got wind of his intentions (he was already grading for the track) they moved to cancel any permits and voted not to allow a drag racing track. In the span of a few weeks that changed to the city offering him 80M (believe the number is correct) in incentives to build a drag racing track when he threatened to close Lowe's and move to another city Your post above got me to thinking about the residents who's subdivision actually will border the track!
Just thinking out loud
When Bernstein broke 300mph at the Gator nationals in March 1992, I was in Gainesville. It seemed as if everyone had a needle in their arm after that blast down the pavement. It was unreal.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 12-02-2007 at 08:14 AM.. |
Damn it was fun believing it while we could.. What about the easter bunny Wayne?? real or urban myth ??
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
