LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
CAn anyone reccomend a decent shower head
The ones available at our local DIY stores are garbage. Does anyone make a low flow head that worth the purchase?
1972 911T/S MFI Survivor
Old 04-07-2008, 03:33 PM
naturally aspirated
Palum6o's Avatar
There was a shower head called the Europa, its small and costs only $5. It gives a power washer effect with just a little pressure.
Old 04-07-2008, 03:59 PM
Monkey with a mouse
kstar's Avatar
I've always liked Speakman shower heads and the "Anystream" is a nice model.
http://www.speakmancompany.com/products/list/Shower
Best,
Kurt
Kurt
http://starnes.com/
Old 04-07-2008, 04:07 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Low-flow sucks. Just use a regular head and shower for a shorter time - put a timer in the shower if necessary (yes, I used to do this until I trained myself to be in, out and done in under 5 minutes) Same effect (same # of gallons used). And at least you get clean. The low-flow jobs I've had ALL required you to stand there (freezing, usually) in vain attempts to get wet enough to wash up.
Black Cars Matter
Old 04-07-2008, 04:12 PM
Anystream by Speakman as kstarnes notes. Around 30 clams.
87 blk coupe
Old 04-07-2008, 04:18 PM
Unconstitutional Patriot
turbo6bar's Avatar
The Commando 450
Old 04-07-2008, 04:26 PM
Moses's Avatar
I have one of those "rain" shower heads. Awful. Like a cow pissing on a flat rock. I bored out the shower head with no improvement. I think the shower mixing valve is low flow. Gotta tear it out.
Old 04-07-2008, 04:30 PM
When I purchased my house in 1991, the low-flow heads were required. As soon as I moved in, the reinstallation of the old, dingy, yellow, high-flow heads was my first priority.
I have very very thick hair, and it would take me quadruple-time rinsing the shampoo and conditioner with those low-flow heads.
Interesting enough, there were 2 'new' low-flow heads that I recently read last week. I was going to buy one as a trial to conserve water. I need to save $$ to buy 87 octane
Old 04-07-2008, 04:34 PM
'low flow'
I don't like the sound of that.
We use the handheld kind with the adjustable heads. Work well. First thing to do is remove the little washer that makes it low flow. In the shower, I need power.
Randy
'87 911 Targa
'17 Macan GTS
Old 04-07-2008, 04:38 PM
Band.
Speakman +1.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 04-07-2008, 06:08 PM
dewolf's Avatar
"Can anyone recommend a decent shower head"
Jenna Jameson?
Old 04-07-2008, 06:25 PM
david914's Avatar
Speakman +3.
My grandparents had one that dated back to at least the early 60's and was still working perfectly up until the 90's when they sold their house (and this is on AWFUL Florida water). I've had them in three different houses and wouldn't use anything else. Built like a tank, fully adjustable, and won't clog. Highly recommended.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 04-07-2008, 06:39 PM
Unregistered
sammyg2's Avatar
Low flow head plus a drill bit equals a good shower head.
Drill em out to get more flow.
Old 04-07-2008, 07:05 PM
Retired in Georgia
Robert Coats's Avatar
Roger that. At the risk of sounding like a pseudonym for a non-traditional sex act, I've been enjoying a "drilled Speakman" for 10+ years now.
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems?
-Robert Coats
Old 04-07-2008, 07:46 PM
Banned
There is usually a flow restrictor in the head that makes it low flow. Just find it and remove it. They are usually in the stem or in the ball joint. It is a plastic mesh basket.
No need to drill. Sometimes there are two but removing both will allow too much water to flow.
Old 04-07-2008, 07:49 PM
I can recommend getting head in the shower.
O2 In Sully We Believe
Old 04-07-2008, 07:54 PM
Monkey with a mouse
kstar's Avatar
In many low-flow models you may find a small, rounded rubber washer at the entrance of the shower head that is the "restrictor" - remove this piece and you can greatly increase the flow.
In new construction I've sometimes found a button type rubber restrictor with three holes upstream of the shower head in the pipe - remove this for better flow.
FWIW.
Best,
Kurt
http://starnes.com/
Old 04-07-2008, 07:56 PM
Senior Member
Grohe. It German, its expensive and its simply wonderful.
Stayed in a 5 star hotel in Switzerland that had them. Got one for the house and been spoiled ever since...
Old 04-07-2008, 08:15 PM
Edministrator
Steve Carlton's Avatar
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 04-08-2008, 12:37 AM
Semper drive!
rcecale's Avatar
Best,
Kurt
For $160.00, it had better be a lot more than "a nice model"!!! Geeze, what's the thread count of your toilet paper???
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 04-08-2008, 03:28 AM
