Student of the obvious
Qantas 747 lands with gaping hole in the side
![]() Can't wait to find out what caused that to happen.
Lee |
Dog-faced pony soldier
It's Bush's fault.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
There goes a perfect safety record.
Was it Rain Man that said he would fly Quantas for that reason?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Nope, there was this one back in 2001:
http://images.google.com/imgres?imgurl=http://www.atsb.gov.au/aviation/editorials/images/e00012_001.jpg&imgrefurl=http://www.atsb.gov.au/aviation/editorials/e00012.aspx&h=288&w=400&sz=44&hl=en&start=1&um=1&tbnid=R4n5exMi4LRMZM:&tbnh=89&tbnw=124&prev=/images%3Fq%3Dqantas%2Baccident%2Bbangkok%26um%3D1% 26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US fficial%26hs%3DSYR%26sa%3DN(Note: not bashing Qantas, their record is remarkable overall)
Super Moderator
Hey! That red duffel bag is mine..... Dammit!
Bondo.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Did someone forget to reset the code in Darma station #3??
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
That was my first thought. Dammit Locke!
The Unsettler
Did something blow a hole in it from the inside?
The hole edges are bent outwards. Or could that have been caused by the skin tearing away, debris flying out of the cargo hold? Someone is gonna need to go shopping for sure.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
The internal pressure of the aircraft, I would presume. At 35,000 feet, the outside air pressure is something like 3.5 psi. If they pressurize the inside of the aircraft to something comfortable for humans (12 psi or so I would guess), you can see that the differential pressure works out to around 9 lbs of force per square inch on the inside of the fuselage. There's lots of square inches on the inside of a plane that large, so the forces are incredible.
Edit: 9 psi is 1296 lbs per sq foot, so section of the plane that large had literally tons of force acting on it.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes Last edited by IROC; 07-25-2008 at 12:01 PM.. |
The Unsettler
I thought they said it was a problem with the door. This stuff is terrifying for me. I get the chills looking at the photos.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
There is no door in that area of the aircraft.
The hole looks worse than it is. Most of the damage is to the fiberglass wing to body fairing, or "A/C fairing". It is neither pressurized nor a structural part of the airframe. If you examine the photo, you will notice the bags are visible in what appears to be an "inner" hole, inboard of the A/C fairing. This is the actual hole in the structure. It took out what looks to be 6-7 stingers, but no frames. There is a "skin lap" in that area, or a top to bottom overlapping of the upper and lower skins. That's kind of significant, structurally. In addition, there is a pretty big wire bundle that passes through there. I bet it didn't do that bundle any good... There is an oxygen bottle located in that area. My guess is that something happened to that bottle; it failed in some way. We'll see. I might get a trip to Australia out of this one, anyway. Pretty easily repaired.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
THE IRONMAN
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Just what I was thinking too.
I'm going to disagree with Jeff, just because we need more tension and fights in here today.
no way man, it was aliens, aliens with dirty nukes and they were trying to kill the koalas with a burning plane from the sky man!!!
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
O.k., let's get this straight once and for all. It was alien bigfoots (bigfeet?) time travelling from the future. They vanished through that hole just as soon as a stewardess noticed they smelled funny and couldn't speak English.
Now you're just talkin' crazy. It may be Friday afternoon, but you still gotta wait until AFTER work to get loaded...
Record still intact.
No deaths.
(As for) Michael Moore:Calling that lying liberal POS propaganda a documentary is like calling PARF the library of congress. I knew it would happen, just not so soon........... |
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
