Student of the obvious
LeeH's Avatar
Qantas 747 lands with gaping hole in the side
Can't wait to find out what caused that to happen.
Lee
Old 07-25-2008, 10:35 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
It's Bush's fault.
Black Cars Matter
Old 07-25-2008, 10:37 AM
There goes a perfect safety record.
Was it Rain Man that said he would fly Quantas for that reason?
Old 07-25-2008, 10:39 AM
Nope, there was this one back in 2001:
http://images.google.com/imgres?imgurl=http://www.atsb.gov.au/aviation/editorials/images/e00012_001.jpg&imgrefurl=http://www.atsb.gov.au/aviation/editorials/e00012.aspx&h=288&w=400&sz=44&hl=en&start=1&um=1&tbnid=R4n5exMi4LRMZM:&tbnh=89&tbnw=124&prev=/images%3Fq%3Dqantas%2Baccident%2Bbangkok%26um%3D1% 26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-USfficial%26hs%3DSYR%26sa%3DN
(Note: not bashing Qantas, their record is remarkable overall)
Black Cars Matter
Old 07-25-2008, 10:51 AM
Super Moderator
cstreit's Avatar
Hey! That red duffel bag is mine..... Dammit!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-25-2008, 10:54 AM
Bondo.
Old 07-25-2008, 10:56 AM
GothingNC's Avatar
Did someone forget to reset the code in Darma station #3??
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 07-25-2008, 11:09 AM
Moses's Avatar
That was my first thought. Dammit Locke!
Old 07-25-2008, 11:22 AM
The Unsettler
stomachmonkey's Avatar
Did something blow a hole in it from the inside?
The hole edges are bent outwards.
Or could that have been caused by the skin tearing away, debris flying out of the cargo hold?
Someone is gonna need to go shopping for sure.
"I want my two dollars"
"Brandon Won"
Old 07-25-2008, 11:48 AM
IROC's Avatar
The internal pressure of the aircraft, I would presume. At 35,000 feet, the outside air pressure is something like 3.5 psi. If they pressurize the inside of the aircraft to something comfortable for humans (12 psi or so I would guess), you can see that the differential pressure works out to around 9 lbs of force per square inch on the inside of the fuselage. There's lots of square inches on the inside of a plane that large, so the forces are incredible.
Edit: 9 psi is 1296 lbs per sq foot, so section of the plane that large had literally tons of force acting on it.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-25-2008, 11:59 AM
The Unsettler
Wow.
"Brandon Won"
Old 07-25-2008, 12:06 PM
Rick Lee's Avatar
I thought they said it was a problem with the door. This stuff is terrifying for me. I get the chills looking at the photos.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
There is no door in that area of the aircraft.
The hole looks worse than it is. Most of the damage is to the fiberglass wing to body fairing, or "A/C fairing". It is neither pressurized nor a structural part of the airframe. If you examine the photo, you will notice the bags are visible in what appears to be an "inner" hole, inboard of the A/C fairing. This is the actual hole in the structure. It took out what looks to be 6-7 stingers, but no frames. There is a "skin lap" in that area, or a top to bottom overlapping of the upper and lower skins. That's kind of significant, structurally. In addition, there is a pretty big wire bundle that passes through there. I bet it didn't do that bundle any good...
There is an oxygen bottle located in that area. My guess is that something happened to that bottle; it failed in some way. We'll see.
I might get a trip to Australia out of this one, anyway. Pretty easily repaired.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 07-25-2008, 12:22 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
All this work as Delta P...differential pressure. Should be around 7 IMO.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 07-25-2008, 12:26 PM
Just what I was thinking too.
Old 07-25-2008, 12:28 PM
I'm going to disagree with Jeff, just because we need more tension and fights in here today.
no way man, it was aliens, aliens with dirty nukes and they were trying to kill the koalas with a burning plane from the sky man!!!
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 07-25-2008, 12:37 PM
O.k., let's get this straight once and for all. It was alien bigfoots (bigfeet?) time travelling from the future. They vanished through that hole just as soon as a stewardess noticed they smelled funny and couldn't speak English.
Jeff
'72 911T 3.0 MFI
Old 07-25-2008, 01:21 PM
Now you're just talkin' crazy. It may be Friday afternoon, but you still gotta wait until AFTER work to get loaded...
Mike Bradshaw
Old 07-25-2008, 01:59 PM
aap1966's Avatar
Record still intact.
No deaths.
(As for) Michael Moore:Calling that lying liberal POS propaganda a documentary is like calling PARF the library of congress.
I knew it would happen, just not so soon...........
Old 07-25-2008, 02:00 PM
sjf911's Avatar
Wow, an alien nuke that fizzled? I thought they were supposed to be lightyears ahead of us.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 07-25-2008, 02:49 PM
