Targa, Panamera Turbo
M.D. Holloway's Avatar
Converting Exhaust Heat Into Electricity
Interesting Stuff - I love crazy materials!
Cars Could Get a Boost from Thermoelectric Materials - Thermoelectric materials could enhance the efficiency of internal combustion engines
By: Gabriel Gache, Science News Editor
Researchers recently invented a new type of compounds, called thermoelectric materials, which could make internal combustion engines and other devices that lose most of the energy they produce through heat more efficient by directly converting the extra amount of thermal energy into electricity.
Thermoelectric materials such as sodium-doped lead telluride alloys have been commercially available for some time, but the efficiency rate was only 0.71. The newly invented material however, thallium-doped lead telluride, has a rating of 1.5, at temperatures between 232 and 510 degrees Celsius, which, as it turns out, is also the temperature range reached by internal combustion engines during operation.
"The material does all the work. It produces electrical power just like conventional heat engines - steam engines, gas or diesel engines - that are coupled to electrical generators, but it uses electrons as the working fluids instead of water or gases, and makes electricity directly. Thermoelectrics are also very small. I like to say that TE converters compare to other heat engines like the transistor compares to the vacuum tube," said Joseph Heremans of the Ohio Eminent Scholar in Nanotechnology at the Ohio State University, leader of the project.
Usually when designing thermoelectric materials, researchers approach a strategy in which the compound's energy conversion capability is achieved by minimizing the heat loss through the material. However, the Ohio team, which had previously worked with nanomaterials in similar directions, decided to abandon the quest for low thermal conductivity and concentrate on how to efficiently convert the heat delivered to the material.
In order to do so, Heremans' team had to back up on some of their early work that suggested that electrons of thallium and tellurium experience quantum mechanical interactions, allowing the electrons of thallium to resonate with those of the lead telluride.
"It comes down to a peculiar behavior of an electron in a thallium atom when it has tellurium neighbors. We'd been working for 10 years to engineer this kind of behavior using different kinds of nanostructured materials, but with limited success. Then I saw this paper, and I knew we could do the same thing we'd been trying to do with nanostructures, but with this bulk semiconductor instead," he said.
With the help of Vladimir Jovovic of the Department of Mechanical Engineering at Ohio State University, Heremans designed the new material which was then created at the Osaka University and put through a series of test to see whether or not predictions were confirmed by experiment. The results of the tests showed that indeed the predicted physical mechanisms were present, giving the materials a rate of efficiency of 0.75 at 232 degrees Celsius and a rating of 1.5 at 510 Celsius.
"We hope to go much further. I think it should be quite possible to apply other lessons learned from thermoelectric nanotechnology to boost the rating by another factor of two - that's what we're shooting for now," Heremans said.
Michael D. Holloway
https://5thorderindustry.com/
Old 08-26-2008, 07:22 AM
abit off center
cgarr's Avatar
Why not just hook your turbo charger direct to a generator? Then use the exhaust heat to boil water for your steam turbine, then use the left over exhaust pressure to power an air generator? by the time your done you have more than you started with?
______________________
Craig
G2Performance
Old 08-26-2008, 08:30 AM
Monkey with a mouse
kstar's Avatar
This, of course, goes against the first law of thermodynamics and is impossible with a generator.
Now, with a gererator, it all makes sense.
Kurt
http://starnes.com/
Old 08-26-2008, 09:16 AM
Feelin' Solexy
Tishabet's Avatar
A huge amount of the potential energy from the gasoline consumed by an internal combustion engine is lost to friction and is expressed as heat. Reclaiming that heat to create more energy seems like a no-brainer as long as the device is cost-effective.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 08-26-2008, 09:49 AM
Tree-Hugging Member
Jim727's Avatar
You guys are forgetting about the Phlogiston Effect....
Actually, this is very cool stuff. Think of materials optimized for cogeneration from cooling towers, smoke stacks, or anything that generates waste heat. Potentially there's a wide range of devices that could become thermoelectric generators.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 08-26-2008, 10:00 AM
Did you get the memo?
onewhippedpuppy's Avatar
Anything is possible with a gererator!
Cool idea and technology. I remember a while back BMW had a gas/steam hybrid engine that used the exhaust and coolant heat to power a small steam turbine. It apparently stayed a concept. It would be nice to improve on the low efficienty of the internal combustion engine, harnessing all of the dissipated heat energy would be a good place to start.
‘07 Mazda RX8-8
Old 08-26-2008, 10:03 AM
meister member
speedracing944's Avatar
Just a regular thermocouple generates voltage when exposed to heat.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-26-2008, 01:10 PM
canna change law physics
red-beard's Avatar
1.5% is crap!
HRSGs (Heat Recovery Steam Generators) in a Power Generation are about 40% thermally efficient. If you recovery the latent heat in the cooling water for heating, it can reach 70%.
Also, what is the cost of an exhaust system based on a Peltier generator? I expect it will be friggen expensive!
James
Red-beard for President, 2020
Old 08-27-2008, 12:52 AM
