CAn anyone reccomend a decent shower head
The ones available at our local DIY stores are garbage. Does anyone make a low flow head that worth the purchase?
David 1972 911T/S MFI Survivor |
naturally aspirated
There was a shower head called the Europa, its small and costs only $5. It gives a power washer effect with just a little pressure.
Monkey with a mouse
I've always liked Speakman shower heads and the "Anystream" is a nice model.
![]() http://www.speakmancompany.com/products/list/Shower Best, Kurt Last edited by kstar; 04-07-2008 at 04:09 PM.. |
Dog-faced pony soldier
Low-flow sucks. Just use a regular head and shower for a shorter time - put a timer in the shower if necessary (yes, I used to do this until I trained myself to be in, out and done in under 5 minutes) Same effect (same # of gallons used). And at least you get clean. The low-flow jobs I've had ALL required you to stand there (freezing, usually) in vain attempts to get wet enough to wash up.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Anystream by Speakman as kstarnes notes. Around 30 clams.
87 blk coupe |
Unconstitutional Patriot
The Commando 450
I have one of those "rain" shower heads. Awful. Like a cow pissing on a flat rock. I bored out the shower head with no improvement. I think the shower mixing valve is low flow. Gotta tear it out.
When I purchased my house in 1991, the low-flow heads were required. As soon as I moved in, the reinstallation of the old, dingy, yellow, high-flow heads was my first priority.
I have very very thick hair, and it would take me quadruple-time rinsing the shampoo and conditioner with those low-flow heads. Interesting enough, there were 2 'new' low-flow heads that I recently read last week. I was going to buy one as a trial to conserve water. I need to save $$ to buy 87 octane
'low flow'
I don't like the sound of that. We use the handheld kind with the adjustable heads. Work well. First thing to do is remove the little washer that makes it low flow. In the shower, I need power.
Randy '87 911 Targa '17 Macan GTS |
Band.
Speakman +1.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
"Can anyone recommend a decent shower head"
Jenna Jameson? |
Speakman +3.
My grandparents had one that dated back to at least the early 60's and was still working perfectly up until the 90's when they sold their house (and this is on AWFUL Florida water). I've had them in three different houses and wouldn't use anything else. Built like a tank, fully adjustable, and won't clog. Highly recommended.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Unregistered
Low flow head plus a drill bit equals a good shower head.
Drill em out to get more flow. |
Retired in Georgia
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems? -Robert Coats |
Banned
There is usually a flow restrictor in the head that makes it low flow. Just find it and remove it. They are usually in the stem or in the ball joint. It is a plastic mesh basket.
No need to drill. Sometimes there are two but removing both will allow too much water to flow. |
I can recommend getting head in the shower.
O2 In Sully We Believe |
Monkey with a mouse
In many low-flow models you may find a small, rounded rubber washer at the entrance of the shower head that is the "restrictor" - remove this piece and you can greatly increase the flow.
In new construction I've sometimes found a button type rubber restrictor with three holes upstream of the shower head in the pipe - remove this for better flow. FWIW. Best, Last edited by kstar; 09-18-2008 at 11:34 PM.. |
Senior Member
Grohe. It German, its expensive and its simply wonderful.
Stayed in a 5 star hotel in Switzerland that had them. Got one for the house and been spoiled ever since...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Semper drive!
![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
