Throw it on the ground!
Gas Shortage in ATL - Can I run Reg vs Premium
There has been no Premium available in Atlanta this week. Stations are only getting Regular, not even mid grade.
Any problem running a tank or two of regular if I have to until supply is available?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Custom User Title
I dunno for sure, but you can go to an autoparts store like a pepboys and buy some octane booster. Assuming its not a scam.
drag racing the short bus
What's with this gas shortage anyway down there? Are other cities short on fuel, or is it just Atlanta?
The Terror of Tiny Town |
Wayah Road Warrior
Atlanta has 'special blend' mandated for enviro reasons. Guess what? Because of that they have no gas. Mandate has been waived for interim until the Colonial pipeline and associated refineries are back to full capacity. Should be sorted out by end of next week.
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) |
Depends on the car. Most modern vehicles have knock sensors that will compensate for lower octane fuel.
Nashville has been having the same issue. I only put in a couple gallons to get me through and then added an octance booster. I haven't been driving the car as hard either.
There wasn't a gas shortage until the media made one. Started talking about it on the radio and tv and gas lines were blocks long and it took hours to get gas.
1976 911 S Targa 3.2 |
Heat plays an issue too, so if it's cool, then it's probably much less of an issue. Your '87 doesn't have a knock sensor, so don't rely on that to save you.
fwiw I ran 87 in my '79 without issue. On track days I made sure that I had 91 in the tank, but for regular driving I never noticed pinging, etc.
Try not, Do or Do not
If the car you are inquiring about is an 84-89 Carrera, you can adjust the ECU for lower fuel quality. There is a rheostat on the side of the ECU (a yellow knob with a triangle slot ? memory is fading) that will retard the timing about 4 degrees. It's easy to change and can be reset to normal when the fuel quality is restored.
Cheers
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Yes I am talking about running regular in my 87 - Its my daily driver and is SW chipped for 93 octane fuel.
Fortunately I was able to top off at a Quick Trip on the way home from the office. Most stations are still dark (no gas). Those that have gas are posting prices for Reg and Diesel only. Lines are long at those stations reminiscent of the mid 70's. Highly populated cities with poor air quality like Atlanta are required to use cleaner burning oxygenated fuels which is in short supply following the recent hurricanes in the gulf. Virtually all stations were out of gas on Sunday. News was that fuel supplies should correct later in the week. Seems to be taking longer. I'll keep topping of whenever I can until the situation stabilizes.
canna change law physics
Do you have an owner's manual? What does it say?
Put in the regular and try it. Try the octane booster and see if it helps, if needed.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Registered Usurper
You can't always hear detonation/predetonation/pinging/knocking - that can destroy your engine - in very short order - as I found out
. It wasn't a Porsche.
'82 SC RoW coupe |
Friend of Warren
If it is a SW chip don't run anything less than 91 octane. Steve advances the timing on his chip and you need the higher octane. A stock U.S. 3.2 engine was designed to run on 87 octane. Says so right in your owners manual.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Team California
Actually, on modern cars w/ more sophisticated ECUs it can be about something else. My dad's Lexus RX 330 states in the owners manual that it can run on 87, but for maximum performance use 93. IOW, it will adjust timing for the octane.
Denis |
I think you'll be fine as long as you don't drive too hard when the temps get up.
We have a shortage of regular/mid-grade here, doesn't phase me since I've always been using 93 octane. I have the compression bumped up to 9.8 and my VW Turbo requires premium.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Also, in '87 I believe the cam timing and also the ECU mappings were changed from the early 3.2L cars. "Changes in the fuel map & chip programming from October 1986, further improved the power to 217 bhp (160 kW @ 5900 rpm) for North American delivered cars..."
Dog-faced pony soldier
Don't bother with octane booster in a bottle - that stuff is garbage and will do nothing. The best ones only raise you by about one tenth of an octane point.
You can mix fuel with either xylene or toluene to raise the octane. Do a Google search for toluene octane booster and read up about it (and yes, I've done this with excellent results in the past). There's a wealth of information out there. It allowed me to run very high boost levels on my old 951 without any pinging or other issues.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Custom User Title
Oh yeah.... I remember there was a guy who had a whole page somewhere about using toluene... you can buy it by the gallon at hardware stores. Wish I could remember the site...
If you Google it, you'll get about 100 explanations of it. Here's a very useful one for reference:
http://www.faqs.org/faqs/autos/gasoline-faq/part1/
Somewhere in the Midwest
IIRC, my '89 Carrera manual says use 91 Pump Octane.
The FQS -Fuel Quality Switch is a small rotary switch inside the DME box, accessible via a hole in the metal DME box (about 1/2 inch diameter). If one hasn't open the box up to see it, be careful. Don't go sticking stuff into the hole or you'll be just like the kid who let his buddy drill into his ZX6 ECU. A small tool (triangular tip) can be made from a long golf tee to insert and make adjustments. Here are the settings: SwitchPosition/Fuel Correction/Ignition Correction 0/0/0 1/+3.1%/0 2/+6.3%/0 3/-3.9%/0 4/0/-2.79° 5/+3.1%/-2.79° 6/+6.3%/-2.79° 7/-3.9%/-2.79° |
