pwd72s's Avatar
Hmmm, what would this slip into?
Maybe a 928???
Ford Racing Performance Parts - [Part Details]
Old 08-04-2010, 07:28 PM
Blah!
If you're going that route, you may as well get something good.
GM Performance 19211710 GM Performance Parts 427 LS7 Engine
GM Performance, using valuable data gleaned from the factory-sponsored Corvette C5R racing program, developed the LS7 with many competition-derived components and design features. It takes production small block performance to an unprecedented level while demonstrating the continuing adaptability of the engine's compact cam-in-block design. It is, quite simply, the largest, most powerful production small block V8 GM has ever produced. Each engine assembled by hand by a single specially-trained builder.
Specifications
# 505 horsepower @ 6200 RPM
# 475 ft/lbs of torque @ 4800 RPM
# 7000 RPM redline
# 11:1 compression ratio
# Unique engine block with larger 4.125" bores and pressed-in cylinder liners
# Forged steel crankshaft with 4.000" stroke
# Titanium connecting rods
# Cast aluminum flat top pistons
# CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
# Dry sump oiling system (does not include lines or tank)
# Camshaft with .591" lift
# Hydroformed exhaust headers with unique quad flow collector flanges
# Intake manifold with injectors (injector wiring harness)
# Fuel rails
# Throttle body
# Exhaust manifolds
# Flywheel and clutch
# Harmonic damper
# Water pump and pulley
# Coil packs, spark plugs, and wires
# Engine sensors
# Engine processor, air filter/air box, and accessory drive NOT included
Old 08-04-2010, 07:50 PM
A930Rocket's Avatar
11:1 compression ratio?
What octane gas does it use?
Old 08-04-2010, 08:00 PM
Free minder
Aurel's Avatar
Could fit in a lawnmower:
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 08-04-2010, 08:08 PM
pwd72s's Avatar
Lessee...$14,500 for the Government Motors engine vs. $7 K for the Ford? Apples & oranges, money wise...
But if you believe there is no replacement for displacement backed by cubic dollars, I'll take that 550 horse chevvy and raise you...
http://www.fordracingparts.com/crateengine/main.asp
Old 08-04-2010, 08:10 PM
Schumi's Avatar
11:1 is not high.
A new 987S has a 12.5:1 compression ratio.
M
Old 08-04-2010, 08:44 PM
AutoBahned
RWebb's Avatar
how about a Go Kart?
or the next closest thing... a 914
Old 08-04-2010, 08:52 PM
pwd72s's Avatar
Yep, computer management systems allow for some pretty high compression ratios these days...even for use with pump gas.
Old 08-04-2010, 08:53 PM
Control Group
Tobra's Avatar
this, maybe a miata or 240-280 Z
Old 08-04-2010, 09:16 PM
pwd72s's Avatar
How 'bout?
Old 08-04-2010, 09:22 PM
Arizona_928's Avatar
Image what you could do to the 5.0L with the 8k difference to the 427. Anyways It's all aluminum, and twin cams... Goodies would definitely be cheaper then to the 928 5.0L
dolor et pavor
Copyright
Old 08-04-2010, 09:56 PM
Bandwidth AbUser
Jim Richards's Avatar
Jim R.
Old 08-05-2010, 03:07 AM
wdfifteen's Avatar
Is it just me, or is doing donuts the biggest waste of time/fuel/tires since the Chevy Vega?
Old 08-05-2010, 03:18 AM
Unregistered
sammyg2's Avatar
Ford Racing Performance Parts - [Crate Engines]
If all you want to do is convert gasoline into noise you could just install a harley engine.
BTW, forced induction beats displacement every time.
Old 08-05-2010, 06:35 AM
Cubic dollars win it all. Look at the F-1 engine.
Old 08-05-2010, 06:40 AM
