Hmmm, what would this slip into?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Blah!
If you're going that route, you may as well get something good. GM Performance 19211710 GM Performance Parts 427 LS7 Engine GM Performance, using valuable data gleaned from the factory-sponsored Corvette C5R racing program, developed the LS7 with many competition-derived components and design features. It takes production small block performance to an unprecedented level while demonstrating the continuing adaptability of the engine's compact cam-in-block design. It is, quite simply, the largest, most powerful production small block V8 GM has ever produced. Each engine assembled by hand by a single specially-trained builder. Specifications # 505 horsepower @ 6200 RPM # 475 ft/lbs of torque @ 4800 RPM # 7000 RPM redline # 11:1 compression ratio # Unique engine block with larger 4.125" bores and pressed-in cylinder liners # Forged steel crankshaft with 4.000" stroke # Titanium connecting rods # Cast aluminum flat top pistons # CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves # Dry sump oiling system (does not include lines or tank) # Camshaft with .591" lift # Hydroformed exhaust headers with unique quad flow collector flanges # Intake manifold with injectors (injector wiring harness) # Fuel rails # Throttle body # Exhaust manifolds # Flywheel and clutch # Harmonic damper # Water pump and pulley # Coil packs, spark plugs, and wires # Engine sensors # Engine processor, air filter/air box, and accessory drive NOT included
11:1 compression ratio?
What octane gas does it use? |
Free minder
Could fit in a lawnmower:
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Lessee...$14,500 for the Government Motors engine vs. $7 K for the Ford? Apples & oranges, money wise...
But if you believe there is no replacement for displacement backed by cubic dollars, I'll take that 550 horse chevvy and raise you... http://www.fordracingparts.com/crateengine/main.asp
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 08-04-2010 at 08:56 PM.. |
11:1 is not high.
A new 987S has a 12.5:1 compression ratio.
M |
AutoBahned
how about a Go Kart?
or the next closest thing... a 914 |
Yep, computer management systems allow for some pretty high compression ratios these days...even for use with pump gas.
Control Group
this, maybe a miata or 240-280 Z
She was the kindest person I ever met |
How 'bout?
Image what you could do to the 5.0L with the 8k difference to the 427. Anyways It's all aluminum, and twin cams... Goodies would definitely be cheaper then to the 928 5.0L
dolor et pavor Copyright |
Bandwidth AbUser
Jim R. |
Is it just me, or is doing donuts the biggest waste of time/fuel/tires since the Chevy Vega?
Unregistered
BTW, forced induction beats displacement every time. |
Cubic dollars win it all. Look at the F-1 engine.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
