JW Apostate
Friend gave me a netbook.
I want to drive a second larger monitor along with the little one on board. How should I do this? Thanks My netbook has a port that the printer cable plugs into. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Doesn't have any sort of video out?
Printer out ain't gunna cut it.. You can try though.. Please video your attempt.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
JW Apostate
Sorry, I meant monitor/VGA cable plugs into.
It flashed the Microsoft screen on the second monitor at startup and then went to the netbook's screen after boot. KT
What OS?
On my dells there is a blue CRT/LCD print on one key... You hit the blue Fn key and hit the CRT/LCD and it cycles the different video options... |
JW Apostate
XP, I think?
It'll be my streaming video viewer/blogger trackside at this weekend's race. I want a bigger screen that passers by can see. ![]() KT
Make/model?
JW Apostate
Acer/ Aspire One
KT
Assuming it is XP...
Right click on the desktop--->properties--->settings---> select output When the monitor is plugged in XP should recognize it... |
JW Apostate
Thanks, I'll give that a shot in the morning.
Thanks again, gents! KT
JW Apostate
I have it set where the second monitor becomes an extended desktop of the netbook.
I can open second windows there. I can put the in-car footage on the big screen and chat with you jokers on the netbook!! ![]() KT
canna change law physics
I own the same Netbook - It is far easier than that.
Hold down the "Fn" key and press the "F5" key three times, and you will be monitor only. I do this everyday. Before unplugging the cable, do the above again, except 4 times. You will see that there are other options (Both on, etc) as you are cycling through the different configurations.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
JW Apostate
Nice!
Thanks! KT
JW Apostate
OK...
I tried the fn-f5 and now the machine won't find the second monitor anymore?!? KT
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
JW Apostate
I figured it all out.
After a restart I got it back. This is good. KT
