Trailer tires are made to withstand UV effects better than car/truck tires.
Old 11-06-2010, 11:54 AM
With the exception of Michelin all trailer tires that I know of are made in China. I own 4 trailers ranging from 20' enclosed to 53' semi car transporter. The smaller tires( 15, 16, 17.5) that are made in China fail at a much higher rate so you have to watch them like a hawk. On a side note if you go to Goodyear's website they are adamant about not trailering over 70 However with my Duramax it's really hard to go that slow
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 11-06-2010, 01:43 PM
RETIRED
Joe Bob's Avatar
Lots of trailers run close to or exceed their weight rating. Fail.
Trailers are left outside and tire walls deteriorate. Fail.
Trailers hit curbs and other obstacles that the tow vehicle misses. Fail.
Trailers get low maintenance, bearings heat up, run low pressure. Fail.
Trailers get the tail end boogie, low pressure tires, wall failure. Fail.
2012 ML350 3.0 Turbo Diesel
Old 11-06-2010, 03:11 PM
JW Apostate
trekkor's Avatar
I'll snap a picture of the tire that was caught just in time...
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 11-06-2010, 03:22 PM
Detached Member
Hugh R's Avatar
My tire guy says its a combination of all those things, especially sitting in one place for months at a time. I take the load off of my camping trailer tires by extending the scissor feet levelers to take the load off the tires.
Hugh
Old 11-06-2010, 03:40 PM
lm6y's Avatar
Also, on a multi axle trailer the tires are "scrubbed" on turns instead of actually turning (not rolling).
Brent
Early85 944
LM6Y Paint Code
Old 11-06-2010, 04:27 PM
JW Apostate
trekkor's Avatar
So close!
KT
'01 Boxster
Old 11-06-2010, 04:42 PM
Platinum Member
dad911's Avatar
WAG but looks to me like shifted cord from pothole or other road debris?
More wear on edges from under-inflation? Center tread looks deeper in pics.
Old 11-06-2010, 04:52 PM
underinflation
Chris
the more i learn, the less i know
Old 11-06-2010, 05:11 PM
Non Compos Mentis
Pshaw! That tire has lots of life left!
Old 11-06-2010, 05:44 PM
RETIRED
Joe Bob's Avatar
Might want to do like the racers do and check tires temps next time on the road. Hand held pyrometer will give edge and middle of the tire temps.
Old 11-06-2010, 05:47 PM
JW Apostate
trekkor's Avatar
Good idea.
I have the pyrometer.
I've been good about tire pressure with these tires.
That wear looks like it took some time, right?
How long would it take to wear the shoulders if I drove on the tires under inflated?
KT
'01 Boxster
Old 11-06-2010, 05:57 PM
RETIRED
Joe Bob's Avatar
Depends on how heavy a load and how twisty the road......
BTW, there are pressure gauges that send an alarm remotely to a receiver in the tow vehicle.
I just got some new LT rated truck tires.....my pressure is 65psi. I flat out forgot they ran that high. Doubt the ex EVER checked them.....
Old 11-06-2010, 06:00 PM
Jim Bremner's Avatar
Originally Posted by trekkor View Post
So close!
KT
what's the psi in that tire 17? way underinflated
Old 11-06-2010, 06:13 PM
JW Apostate
trekkor's Avatar
Nope, 49.
Sidewall requires 50.
KT
'01 Boxster
Old 11-06-2010, 06:27 PM
Man, something isnt right! the load isn't being carried by most of the tire!
Old 11-06-2010, 06:32 PM
Belt shifted. POS tire. What brand and where and when( both on the sidewall) was it built?
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 11-06-2010, 07:31 PM
JW Apostate
trekkor's Avatar
OK..
I went out and looked again.
This is a Carlisle brand trailer tire.
11th week of '08 build date. ( 1108 )
Upon further inspection the psi is recommended at 65.
The other three are 50.
Could this happen over 120 miles?
The distance I towed on Friday.
KT
'01 Boxster
Old 11-06-2010, 08:19 PM
RETIRED
Joe Bob's Avatar
It doesn't take long....
Old 11-06-2010, 08:24 PM
Licensed User
Shuie's Avatar
PV=nRT
Old 11-06-2010, 09:07 PM
