Team California
speeder's Avatar
Need quick help with epoxy/welding problem:
I'm at yet another impasse with the 356, the engine is now ready to go in save for this little problem with the heater boxes. I've let this one go until now because I was busy with other things but now I need to solve it or install them with no working heat and deal w/ it later. (They were not previously working).
Basically, I need to attach this shaft to its flap/valve while it's installed in the HB. I took it to my welder and he could not assure me that his MIG welder would not warp/melt the flap even with a small/quick tack weld. The factory somehow crimped these on with a tiny weld, you can see the marks on the shaft and flap.
I either need to drill tiny holes in both parts and find small screws and/or use some super-duper epoxy that is heat-resistent to attach the parts together. I don't know my epoxy products and this would be a 1-shot deal, ie. if it does not work, the part would be really mucked-up.
New heater boxes are available for ~$300 each but need to be shipped. I need to install the motor today and would love to fix this box cheaply. Thanks in advance as always.
Here is the offending part:
Denis
Old 02-11-2011, 10:47 AM
gtc gtc is offline
abides.
gtc's Avatar
Know anyone with a spot welder?
Graham
1984 Carrera Targa
Old 02-11-2011, 10:54 AM
Detached Member
Hugh R's Avatar
If you won't be able to get at it again easily, I'd drill, tap and machine screw with lock washer and high tensile strength (2 hour) epoxy.
Hugh
Shaun @ Tru6's Avatar
JB Weld will work, as with all epoxy, surface prep is everything.
Tru6 Restoration & Design
Old 02-11-2011, 10:56 AM
Seahawk's Avatar
If it has to go today, JB Weld is fine...how hard is it to get to later?
1996 FJ80.
Old 02-11-2011, 10:57 AM
Team California
speeder's Avatar
Is JB weld really heat-resistent? (Never used it).
Denis
Team California
speeder's Avatar
Any work involving heat exchangers is an engine drop + exhaust removal. Which is not the end of the world on these cars but it would be nice to fix this one before installing. The HE on the other side is junk so the engine is coming out again either way but I could at least have heat on one side.
Denis
Old 02-11-2011, 11:00 AM
Team California
speeder's Avatar
That would be a great repair but for time reasons it's dead. Thanks just the same.
Denis
Old 02-11-2011, 11:01 AM
Control Group
Tobra's Avatar
what about drilling through it and rivet together, or grind a flat spot on shaft and use a punch to get flap in close approximation to flat spot
How different is that piece from a bug of similar vintage?
Old 02-11-2011, 11:08 AM
Eric 951's Avatar
What about drilling a hole through the shaft/flap and using a cotter pin?
Eric
83 911SC/83 944
bunch of Honda 750s
MAGA
Tim Hancock's Avatar
If you need to weld the flap to the shaft, I would simply drill a couple small holes in the flap where the original crimp indentations are and then I would simply rosette weld them with the tig welder..... Very simple IMO...
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-11-2011, 11:11 AM
Detached Member
Hugh R's Avatar
Drill and cotter pin then, don't trust the epoxy in torsion.
Hugh
Old 02-11-2011, 11:20 AM
Senior Member
Superman's Avatar
Sure sounds possible. Maybe I'm missing something. Most if not all the above suggestions are excellent. What's so hard about drilling through both pieces and driving an interference-fit pin in there? Or as Tim says, open a couple of little ports in the sheet metal, and weld there. If the engine and exhaust will need to come out eventually, then you lose nothing with the gamble. Worst case scenario: The sheet metal gets a bit warped.
Mocha 1978 911SC. "Coco"
Old 02-11-2011, 11:23 AM
Un Chien Andalusia
Aerkuld's Avatar
I'd drill a small hole through the flap and the shaft and pin the two together. Possibly two small holes, one on each of the flats. Alternatively, do as Graham suggested and find someone with a spot welder.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 02-11-2011, 11:24 AM
wdfifteen's Avatar
THIS IS THE WAY TO DO IT. There won't be any warping problems.
Short of this, epoxy the shaft to the flap. The problem with that is getting enough epoxy between the sheet metal and the shaft.
Old 02-11-2011, 11:31 AM
MAGA
Rosette weld..... I promise it will work perfectly and is the easiest/quickest way to get the job done right. (unless of course you have a specially configured tongs for your spot welder that can fit inside the heat exchanger opening and still squeeze/weld the parts together)
0% Liberal
Old 02-11-2011, 11:33 AM
Senior Member
Spot welding is what I would use. Gotta be someone around with one. I have a small one from HF that I use...
Old 02-11-2011, 11:39 AM
wdfifteen's Avatar
Maybe there is an issue of semantics here. I don't see how anyone would get a spot welder down in there.
It was swedged on to begin with. That might be an option, just deform the hole in the plate so badly that you have to hammer the shaft through it. Inelegant, yes, but it would work just fine. I would probably do just that if it was mine, but Tim's suggestion is the best permanent, fool proof solution.
Old 02-11-2011, 11:46 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I've used it to fix rusted out holes in mufflers. Surface prep is everything.
Old 02-11-2011, 11:52 AM
Seahawk's Avatar
Honestly, Tim, WTF do you know...I mean, really
1996 FJ80.
Old 02-11-2011, 12:26 PM
