crustychief's Avatar
"The beast" high centered in Dublin
Sorry if it is a repost.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 05-24-2011, 07:59 AM
So, does it look like the suspension collapsed, or do you think it just high centered?
Old 05-24-2011, 08:16 AM
RETIRED
Joe Bob's Avatar
Armored limo, high centered.....you would think they would have fixed the hump, been aware of it and took at an angle or exited another way. Bet some heads rolled on this faux paus....
2012 ML350 3.0 Turbo Diesel
Old 05-24-2011, 08:41 AM
Banned
lol. Need a push mate?
Old 05-24-2011, 08:45 AM
I have to agree. It sure looks like the front suspension collapsed.
Old 05-24-2011, 08:46 AM
That RR tire come off the ground.
Old 05-24-2011, 09:07 AM
Do you think they are running airbags and something like the gate track breached a line under the car. Like the oil lines on the 911?
Old 05-24-2011, 09:15 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Watch closely and you can see the front suspension collapse. Compare the front ride height before and after and it's about a foot lower in the front. If it were a high center there would be less weight on the suspension and ride height would be increased.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-24-2011, 09:17 AM
It definitely high-centered. The BMW before it hit the ridge as well. There are other videos of the same event from different angles and they show it better.
I love you guys outside this forum
-Eric
Old 05-24-2011, 09:21 AM
Scott R's Avatar
That thing must have amazing armor underneath it. I saw a Lincoln collapse once in a parking lot, the owner tried to drive it home and tore the fuel lines and the oil pan out. There was fluid everywhere all over the driveway. This thing seems to be pretty un-phased with exception to the front air bags.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Sultan of Sawzall
rouxroux's Avatar
Too much haggis for Moosechelle
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 05-24-2011, 09:22 AM
Harsh
very harsh
Old 05-24-2011, 11:34 AM
Gon fix it with me hammer
svandamme's Avatar
that bmw in front already came close to belly scraping... so my guess, something snagged, and yanked the front end down with a clunk...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-24-2011, 12:06 PM
abit off center
cgarr's Avatar
I thought he had a KW HLS (Hydraulic Lift System) put on when he took over?
______________________
Craig
G2Performance
Old 05-24-2011, 12:20 PM
Here's another angle, with clear audio
Listen at 9 secs, then again at 16
-Eric
Old 05-24-2011, 12:38 PM
unindicted co-conspirator
looneybin's Avatar
you would think the advance team would have run a test to make sure the limo could drive down the route.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 05-24-2011, 03:28 PM
Yet another angle:
-Eric
Old 05-24-2011, 03:36 PM
abit off center
cgarr's Avatar
Almost looks like there were steel plates in the ramp that gave away when the front tires hit it? This thing weights a ton, well several tons!
Craig
G2Performance
Old 05-24-2011, 03:55 PM
304065's Avatar
Whatever the reason that is a major, major security foul up and somebody has probably been fired over it.
High-centering the POTUS? Consider the vulnerability. So much of any security playbook depends on having an evasion route present-- no matter how bad it gets I can imagine priority #1 is to GET THE HELL OUT OF THERE. Then the guys up front just casually open the doors? I would have brought in a boatload of cover before I opened up that thing.
Just my humble opinion as a paranoid New Yorker where you constantly have your head on a swivel.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-24-2011, 05:20 PM
1.367m later
KevinP73's Avatar
Don't they have two of those beasts? Perhaps POTUS wasn't in the front limo(think shell game). I did notice the front passenger door started to open but then went back shut. Either way, why on earth would the driver get out in any case?
Old 05-24-2011, 05:27 PM
