1.367m later
One point!! Failed by ONE point
Effin smog nazis failed my truck for being one friggen point over the limit. I just rebuilt the engine, it's running perfect but at 25mph it emits 35 HCs instead of 34. How pissed am I?
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
abit off center
How accurate is their equipment?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
The Unsettler
Run the tank as low as you can, add a couple bottles of dry gas then put in only enough premium as needed to get it to the inspection station and run the tests. Idea is to get it to run on as much alcohol as you can.
Friend of mine who owns a shop told me that a bunch of years back when my car failed, worked like a charm.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
Get a haircut before going in to the test station.
Canucks Fan
close only counts in hand grenades
Unregistered
Regular unleaded gas burns cleaner than premium during smog tests ................
Would it make you feel better if you failed by several points?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Are you sure?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
...u still have sniffer emissions?
run some e85 in there. |
Slackerous Maximus
As we speak, a guy in India is throwing a ball of plastic bags on a fire to keep warm. Oh wait, make that 1,000,000 guys.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Control Group
and government works
if the coil or distributor is a bit tired, you can get elevated HC on the sniffer, seen old plug wires do that too You could always just pretend you only speak Spanish and don't have any license, insurance or registration, then they would just let you go. What color are your eyes and hair?
She was the kindest person I ever met |
disband
yeah, thats what ive heard. the higher octane takes more heat to burn effective like so easier burn less do-do with lower octane.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
one of gods prototypes
maybe the problem isn't the truck but the state you live in.........
Brought to you by Carl's Jr. |
High HCss can be caused by fuel contaminated engine oil. .A rebuilt engine often lets more fuel past it,s unseated rings and add some fuel to the oil. The PCV system will suck up the fumes and increase unburned HC in the tailpipe. Small amounts can make enough difference to fail . A good long hot highway run will burn off most as will an oil change (smell the dipstick and change the oil if you smell any fuel).
Timing off a couple deg. either way will also affect HC. If your HC was high caused by timing then your NOx would likely be on the low end of acceptable.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Florida should bring back etesting. I have a winter home in Tarpon Springs Fl. Florida has more than it,s fair share of "stinky" old cars.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 06-08-2011 at 04:50 PM.. |
Control Group
It may not pass until after your first oil change if motor is freshly rebuilt
i have to saw i see a hell of alot LESS smokey/smelly cars in florida than the previous 30 years in ohio.....who has e-check.......what does canada test for?
Ontario tests vehicles on a dyno at idle and 25mph . Sniffs 3 gases HC,Nox and CO Plus gas tank cap seal is verified.Exhaust systems are supposed to be leakfree to be able to be tested. Vehicles are tested every other year . No testing on pre 1988 cars but catalysts and other equipment can,t legally be removed /disabled. A gross polluter (oil burner cloud) can be stopped by the police and ordered off the road until repaired but that seldom happens. There is a $400 repair limit for a failed car.Taxis and commercial are also tested but there is no cap on repair costs.. There are fewer old cars still on the road here than Florida as our cars are subjected to winter road salt.Some norther counties are not tested presumably because of small numbers of cars. More travel by snowmobile you know
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 06-08-2011 at 07:15 PM.. |
