RedBaron's Avatar
New Apple Operating System: 10.7 "Lion"
Just did a clean install. Overall I'm very impressed. My only complaint is the fact that they screwed up spaces and expose and turned it into "mission control." I also got rid of the optical drive in my mac and purchased a 40GB SSD from OWC which houses the "OS" and I have my 500GB 7200RPM which houses the "data." Overall, the OS is lightening fast on my three year old macbook pro. Well worth the $30 for an upgrade...They should deffinitely fix spaces though.
Old 07-20-2011, 08:53 PM
enzo1's Avatar
no bugs? looking forward to it, been reading about it....and it's cheap
76' 911s Signature Edition
Old 07-20-2011, 08:55 PM
"O"man(are we in trouble)
widgeon13's Avatar
I want but the speed of my connection, probably take a day to download 4 GB. Maybe in a week or so.
Old 07-21-2011, 07:46 AM
The Unsettler
stomachmonkey's Avatar
I like that they did away with the family pack and the $30 is valid for every iTunes authorized computer that have.
Nice.
"I want my two dollars"
"Brandon Won"
Old 07-21-2011, 08:09 AM
Damn I wish I knew more about puters. I'd try installing
O2 In Sully We Believe
Old 07-22-2011, 05:01 AM
Shaun @ Tru6's Avatar
Mark, if you can click, you can install.
Tru6 Restoration & Design
Old 07-22-2011, 05:17 AM
Hey Shaun
I guess I'm more concerned on what happens to the other OS things like that. And the guys concerns over some window thingies
Old 07-22-2011, 05:28 AM
If I buy it once can I put it on both my macs? Maybe I'll just get the thumb drive from apple.
Old 07-22-2011, 05:31 AM
The Unsettler
Yes. Just needs to be authorized to the iTunes account.
"Brandon Won"
Old 07-22-2011, 05:57 AM
jeffgrant's Avatar
Not true. You just have to log into the App Store on the machine you want to install it on, and it will recognize it as a previous purchase and allow you to download and install it.
The account is linked to your iTunes account for payment, but there is no concept of "authorized computer" in the App Store like there is in iTunes.
The license says you can install it on any computer you own or control.
I've just upgraded 5 machines in my home office, and 3 of them have never run iTunes, never mind been an iTunes authorized computer.
EDIT: To be clear, I interpreted your comment to mean you have to have an iTunes authorized computer, which is a specific requirement for some audio books, etc., as I've seen others mention. If that wasn't your meaning, apologies... just trying to add clarification.
Old 07-22-2011, 09:47 AM
The Unsettler
Correct, should have said needs authenticating with your Apple ID.
"Brandon Won"
Old 07-22-2011, 10:01 AM
jeffgrant's Avatar
Also, if you download it on one computer, quit the installer when it automatically launches, and look under your Applications folder. You'll see the installer file. You can copy that to other machines and install from it if you don't want to re-download the installer every time.
Once you've copied it, go ahead and re-launch it, and carry on with your installation.
Old 07-22-2011, 10:02 AM
jeffgrant's Avatar
And if you have multiple Macs in an environment and want to set up your own local update server, rather than have each machine download from Apple, I'd recommend looking at Reposado
https://github.com/wdas/reposado
It's a very cool set of Python scripts put together by Disney to allow you to set up a local update repository.
Old 07-22-2011, 10:05 AM
RedBaron's Avatar
You can easily burn the file to a disk once you download it.
Go to Applications, right click "Install Lion" and select show package contents ->Contents -> SharedSupport and then COPY (NOT DRAG) InstallESD.DMG to your desktop. Then open disk utility (Application -> Utilities) and drag the InstallESD file to sidebar, once that is selected hit "burn" and insert a blank DVD.
You now have an installation disk. You can also do it to a 5GB flash drive as well. (Similar method but slightly different)
Buckterrier, I can walk you through it via PM if you want...Hell even the phone could work...You're about 45 mins away from me if worse comes to worst.
I highly recommend a clean installation if your mac is somewhat slowing down.
My impression so far of Lion is about a 9.5/10. I am starting to get used to mission control...Still not as good as Spaces, though!
Old 07-22-2011, 12:12 PM
jeffgrant's Avatar
The only problem I've run into is with Parallels, where it doesn't seem to attach the virtual machine window to any of the desktops. Simple fix (right click on the dock icon, options, all desktops), but was still a bit of a hiccup.
Old 07-22-2011, 01:12 PM
jyl jyl is online now
jyl's Avatar
Just upgraded.
MS Office no longer works - it was an old version from the PowerPC days. Irritating that I have to pay $150 for Office X. I don't use Word or Excel or Powerpoint much at home - how are Apple's Pages or Numbers as alternatives? Will they open/edit/save Office files w/ problem?
Old 07-23-2011, 09:46 AM
Just upgraded.
Give OpenOffice a try. It's probably not as refined as Pages or Numbers, but it's free.
Neil
'73 911S targa
Old 07-23-2011, 09:52 AM
techweenie's Avatar
Just upgraded.
I've been using Pages and Numbers interchangeably with Office 2008 and both are great apps in their own right. If you don't have to send editable files to Windoze users, you will be more than fine with the Apple apps.
Just installed Lion. Some functions appear snappier... Mail is improved. so far so good.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 07-23-2011, 10:31 AM
So worth the $29?
Old 07-23-2011, 10:34 AM
techweenie's Avatar
For me, the jury is still out. Likely will have beaten on it sufficiently by Monday evening to know for sure.
1969 coupe hot rod
Old 07-23-2011, 10:37 AM
