Interesting engine
Scott '78 SC mit Sportomatic - Sold |
Fleabit peanut monkey
This is a step-change increase in the term "interference engine".
Pretty cool. |
Max Sluiter
I don't see that working- the pistons coming out of the cylinder and then staying perfectly co-axial until they mate again. The gear backlash and such would require cylinder walll clearance that could not be taken up with a piston ring, since you need a ring compressor to get a piston+rings into a cylinder. The large clearance then means low efficiency due to blowby. Then there is lots of wingage losses unless you have a big pump to evacuate the crankcase, in which case that pump creates parasitic losses.
Piston engines are not perfect but they sure are a great compromise in many ways. The OPOC engine seems like a better idea to me. Rotaries had advantages and disadvantages. Same for turbines.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 02-06-2012 at 05:20 PM.. |
Max Sluiter
I remember watching Gilligan's Island on TV Land in the evenings. That was back when I was in grade school. Good times. I always preferred Mary-Anne to Ginger.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Ginger had some game if you pulled her off the G.I set. Mary Anne otherwise.
Did you bother to look at the videos?
They have a working propane powered engine running in one of them.
Banned
Your right, it is interesting. But the fact that they can make a propane model run does not mean its an efficient way of burning anything. It doesn't seem to pass the Occams sniff test.
I did. Button #5. Right after the video of the hand cranked version. I did not review the entire website so I do not understand why it is super efficient and I do not understand in every day terms what the application(s) are.
They say it is good for a diesel engine because of it's super long stroke. Your thoughts? |
AutoBahned
Max Sluiter
I still think it would have a lot of losses from blow by, and windage. It also has a lot of parts moving, maybe more than a piston engine of comparable power/efficiency. How are they initiating spark?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Oh my goodness, imagine any of that lot getting the slightest bit out of synchronicity: i hope the casing is strong enough to contain the flying components!!!
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
It IS interesting. It apparently works, though I'm skeptical of announcements like these that are long on marketing for public consumption. I have to wonder why they're promoting to the public instead of to some manufacturer. Some of the claims are a little sketchy too. I it really non-reciprocating? Both the pistons and the cylinders seem to be changing direction once every revolution.
Max Sluiter
I believe it is not technically reciprocating since they move in a circle rather than a straight line.
canna change law physics
I expect the DOE will buy this. Wow, there are some really "interesting" engineers "out there".
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Max Sluiter
I think OPOC, HCCI, Diesotto, etc. are better paths to take. If you want efficiency go high bypass gas turbine.
