LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Interesting engine
This looks interesting...
circlecycleice.com - Home
Comments?
Scott
'78 SC mit Sportomatic - Sold
Old 02-06-2012, 04:34 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This is a step-change increase in the term "interference engine".
Pretty cool.
Old 02-06-2012, 05:06 PM
Max Sluiter
Flieger's Avatar
I don't see that working- the pistons coming out of the cylinder and then staying perfectly co-axial until they mate again. The gear backlash and such would require cylinder walll clearance that could not be taken up with a piston ring, since you need a ring compressor to get a piston+rings into a cylinder. The large clearance then means low efficiency due to blowby. Then there is lots of wingage losses unless you have a big pump to evacuate the crankcase, in which case that pump creates parasitic losses.
Piston engines are not perfect but they sure are a great compromise in many ways. The OPOC engine seems like a better idea to me. Rotaries had advantages and disadvantages. Same for turbines.
Old 02-06-2012, 05:09 PM
Bob Kontak's Avatar
Not only that, they have to stay lined up!
Old 02-06-2012, 05:17 PM
Max Sluiter
Flieger's Avatar
I remember watching Gilligan's Island on TV Land in the evenings. That was back when I was in grade school. Good times. I always preferred Mary-Anne to Ginger.
Old 02-06-2012, 05:21 PM
Bob Kontak's Avatar
Ginger had some game if you pulled her off the G.I set. Mary Anne otherwise.
Old 02-06-2012, 05:51 PM
Did you bother to look at the videos?
They have a working propane powered engine running in one of them.
Scott
Old 02-06-2012, 06:21 PM
Slackerous Maximus
HardDrive's Avatar
Your right, it is interesting. But the fact that they can make a propane model run does not mean its an efficient way of burning anything. It doesn't seem to pass the Occams sniff test.
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 02-06-2012, 06:45 PM
Bob Kontak's Avatar
I did. Button #5. Right after the video of the hand cranked version. I did not review the entire website so I do not understand why it is super efficient and I do not understand in every day terms what the application(s) are.
They say it is good for a diesel engine because of it's super long stroke.
Your thoughts?
Old 02-06-2012, 07:01 PM
AutoBahned
RWebb's Avatar
uh oh - now we're into Slasher movies...
Old 02-06-2012, 08:27 PM
Max Sluiter
Flieger's Avatar
I still think it would have a lot of losses from blow by, and windage. It also has a lot of parts moving, maybe more than a piston engine of comparable power/efficiency. How are they initiating spark?
Old 02-06-2012, 10:25 PM
slodave's Avatar
circlecycleice.com - Image Gallery
Old 02-06-2012, 10:35 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Oh my goodness, imagine any of that lot getting the slightest bit out of synchronicity: i hope the casing is strong enough to contain the flying components!!!
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 02-07-2012, 06:49 AM
wdfifteen's Avatar
It IS interesting. It apparently works, though I'm skeptical of announcements like these that are long on marketing for public consumption. I have to wonder why they're promoting to the public instead of to some manufacturer. Some of the claims are a little sketchy too. I it really non-reciprocating? Both the pistons and the cylinders seem to be changing direction once every revolution.
Old 02-07-2012, 08:10 AM
Max Sluiter
Flieger's Avatar
I believe it is not technically reciprocating since they move in a circle rather than a straight line.
Old 02-07-2012, 02:52 PM
canna change law physics
red-beard's Avatar
I expect the DOE will buy this. Wow, there are some really "interesting" engineers "out there".
James
Red-beard for President, 2020
Old 02-07-2012, 03:46 PM
Max Sluiter
Flieger's Avatar
I think OPOC, HCCI, Diesotto, etc. are better paths to take. If you want efficiency go high bypass gas turbine.
Old 02-07-2012, 03:56 PM
