LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Interesting engine
This looks interesting...
circlecycleice.com - Home
Comments?
Scott
'78 SC mit Sportomatic - Sold
Old 02-06-2012, 04:34 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This is a step-change increase in the term "interference engine".
Pretty cool.
Old 02-06-2012, 05:06 PM
Max Sluiter
Flieger's Avatar
I don't see that working- the pistons coming out of the cylinder and then staying perfectly co-axial until they mate again. The gear backlash and such would require cylinder walll clearance that could not be taken up with a piston ring, since you need a ring compressor to get a piston+rings into a cylinder. The large clearance then means low efficiency due to blowby. Then there is lots of wingage losses unless you have a big pump to evacuate the crankcase, in which case that pump creates parasitic losses.
Piston engines are not perfect but they sure are a great compromise in many ways. The OPOC engine seems like a better idea to me. Rotaries had advantages and disadvantages. Same for turbines.
Old 02-06-2012, 05:09 PM
Bob Kontak's Avatar
Not only that, they have to stay lined up!
Old 02-06-2012, 05:17 PM
Max Sluiter
Flieger's Avatar
I remember watching Gilligan's Island on TV Land in the evenings. That was back when I was in grade school. Good times. I always preferred Mary-Anne to Ginger.
Old 02-06-2012, 05:21 PM
Bob Kontak's Avatar
Ginger had some game if you pulled her off the G.I set. Mary Anne otherwise.
Old 02-06-2012, 05:51 PM
Did you bother to look at the videos?
They have a working propane powered engine running in one of them.
Scott
Old 02-06-2012, 06:21 PM
Banned
Your right, it is interesting. But the fact that they can make a propane model run does not mean its an efficient way of burning anything. It doesn't seem to pass the Occams sniff test.
Old 02-06-2012, 06:45 PM
Bob Kontak's Avatar
I did. Button #5. Right after the video of the hand cranked version. I did not review the entire website so I do not understand why it is super efficient and I do not understand in every day terms what the application(s) are.
They say it is good for a diesel engine because of it's super long stroke.
Your thoughts?
Old 02-06-2012, 07:01 PM
AutoBahned
RWebb's Avatar
uh oh - now we're into Slasher movies...
Old 02-06-2012, 08:27 PM
Max Sluiter
Flieger's Avatar
I still think it would have a lot of losses from blow by, and windage. It also has a lot of parts moving, maybe more than a piston engine of comparable power/efficiency. How are they initiating spark?
Old 02-06-2012, 10:25 PM
slodave's Avatar
circlecycleice.com - Image Gallery
Old 02-06-2012, 10:35 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Oh my goodness, imagine any of that lot getting the slightest bit out of synchronicity: i hope the casing is strong enough to contain the flying components!!!
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 02-07-2012, 06:49 AM
wdfifteen's Avatar
It IS interesting. It apparently works, though I'm skeptical of announcements like these that are long on marketing for public consumption. I have to wonder why they're promoting to the public instead of to some manufacturer. Some of the claims are a little sketchy too. I it really non-reciprocating? Both the pistons and the cylinders seem to be changing direction once every revolution.
Old 02-07-2012, 08:10 AM
Max Sluiter
Flieger's Avatar
I believe it is not technically reciprocating since they move in a circle rather than a straight line.
Old 02-07-2012, 02:52 PM
canna change law physics
red-beard's Avatar
I expect the DOE will buy this. Wow, there are some really "interesting" engineers "out there".
James
Red-beard for President, 2020
Old 02-07-2012, 03:46 PM
Max Sluiter
Flieger's Avatar
I think OPOC, HCCI, Diesotto, etc. are better paths to take. If you want efficiency go high bypass gas turbine.
Old 02-07-2012, 03:56 PM
