Towing 914 with Tacoma
Has anyone towed a 914 on a uhaul trailer with a standard 4 cyl 2010 Tacoma? No towing package but I have a Curtis hitch that is rated 5000 lbs mounted to the frame.
Just making sure I am not pushing my luck.
1973 914-6 Conversion 2.7, crank fired, twin plug. 2006 997.1 Carrera S Cabriolet |
I think you're pushing your luck. I tow my 2400 lb 911 on a 1000 lb aluminum trailer with a 3.4L V6 Tacoma (with a factory towing package and transmission cooler) and it is barely adequate. It accelerates and goes down the highway acceptably, but the brakes are marginal (even with electric trailer brakes). IIRC, a U-Haul trailer is very heavy.
Is this a "one-time-only-just-get-the-car-to-the-house" type of tow? No hills, etc? If so, then you're probably OK, just take it easy. If you're going to do this on a regular basis, I would opt for a better tow vehicle. YMMV and all that. ![]()
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
^ what he said.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Yes this is just to get the car home. Approx 3 hours of highway driving. The Uhaul trailer is 2200 and the car 2000. The GVW on the truck is I think 4900. What about a tow dolly? Since the car has been stored for over 20 years, I would hate to destroy the transmission or something.
Make sure your brake fluid is fresh and leave plenty of room. Check the manual, I would not engage overdrive assuming you have a slushbox. It'll be fine.
Pick a route with the fewest hills!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Do the car Dolly thing, it's lighter than the trailer. I towed my 911 on a tow dolly both ways over a mountain pass with the Toyota 3.0 V6. Was able to easily do the speed limit (60 with a trailer) and just gear down for the inclines.
I sure wouldn't do it every day, just moving 2 911's between houses for winter storage. I used a 4 cyl for years to tow 2 snowmobiles.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
You can go to the u-haul web site and there is an app to see if they will rent it to you for this combination.
go here U-Haul rentals: Cargo, utility and car trailer rentals make up a pickup zip code and hit get rates. Then enter your vehicle
Rick 88 Cab |
Hilbilly Deluxe
As long as it is relatively flat, it should be fine. Not something I would do all the time, but for a one time deal go for it.
if it is such a short trip..why dont you rent a truck with it?
hate to sacrifice safety for a few hundred bucks.
poof! gone |
Puny Bird
Uhaul car trailers are big heavy units, can you rent a car dolly?
This is my light car trailer behind a four banger, even this is pushing the limits.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
I have towed a lot of stuff with my 1999 4 cyl Tacoma: it was for 6 years my only farm truck.
The key really is the trailer brakes and can your truck use them? Trailer brakes are essential for this run. Also, how much have you towed? That is important: not a slight, but tow time is important when you're towing at the margins. If not, local only, 150 miles is a road too far, even with all due regard for safety, etc. Again, the truck will tow it (the engine and trans will be fine), it is, as always, control of the load behind you. The dolly may not be the answer on wheel bearing that have been stored for 20 years. I'd rent both a truck and the trailer as Vash mentioned.
1996 FJ80. Last edited by Seahawk; 02-14-2012 at 09:23 AM.. |
Even with a flat terrain you will be pushing it. I just brought back a 914 parts car on a uhaul trailer from Northern Alabama (close to Chattanooga)...the first 20 miles coming home had a series of steep hills and switchbacks....glad I had my 2006 turbodiesel F-250. I don't think a lesser truck would have made it. The uhaul trailer itself will be a load on a 4 cylinder.
![]() Last edited by billh1963; 02-14-2012 at 09:29 AM.. |
canna change law physics
Use a tow dolly, but back the 914 onto the tow dolly. Lock the steering wheel. I towed my 914/6 from San Diego to Houston this way with my Jeep Cherokee (6 cyl). The front discs will warp on the Jeep if you are not careful on the breaking. Check your brake setup.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
MAGA
I towed a Ford 9n tractor on a lighter tandem axle landscape trailer a couple times without trailer brakes with my old '99 Tacoma 4x4 auto 4 cyl. Power was not an issue, but braking was marginal.... it was by no means safe.
That said, it is your call.... could go fine, but it could end up with you rear ending someone in traffic.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Puny Bird
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 02-14-2012 at 12:01 PM.. |
Look around on the highway.. there are a lot WORSE choices than where you stand. As long as Uhaul will let you (sometimes they ask too many questions about what you tow) then go for it. Be slow.. be safe.. plan ahead.. You will be fine.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Thanks All,
I think I have to have it pulled out and flat bedded. The tires are all flat and the brakes siezed. I think I made a $1700 mistake. I just posted on 914 World a couple of pics with mouse included!
Puny Bird
Got a linky? I don't see it on 914world.
1973 914-6 Conversion 2.7, crank fired, twin plug. 2006 997.1 Carrera S Cabriolet Last edited by wndsnd; 02-14-2012 at 04:05 PM.. Reason: wrong link |
Thread Tools | |
Rate This Thread | |
