Emi Emi is offline
IMS replacement after failuer
Hello,
Has anyone been able to replace a bearing after a failure , given metal particles in the oil. Wondering if possible to flush out the particles. This is provided the ims bearing shaft has not been dameged e.g snap ring is groove is still present.
regards,
Old 02-26-2012, 07:11 PM
KNS KNS is online now
I believe that if the bearing fails, not only does it spread metal debris throughout the engine but a bunch of other damage occurs as a result of the failure.
Did the engine come to a stop?
Kurt
Old 02-27-2012, 05:35 AM
Emi Emi is offline
re: IMS replacement
Hi,
Thank you for the response. No, engine is fine timing on and ims replaced 20,000 miles and counting . I Checked timing before replacing and spot on only indication was ims center bolt snapped and leaked oil stopped and replaced right away and non issue since. Only concern is longevity and if others have had similar success?
Old 02-27-2012, 06:07 AM
Did you get the memo?
onewhippedpuppy's Avatar
I've read of several instances similar to this, the owners changed the oil and filter multiple times at short intervals to help flush the system. At this point what do you have to lose?
Old 02-27-2012, 06:39 AM
recycled sixtie's Avatar
How did u manage to detect the ims failure so soon without doing major damage? You must have shut down the motor when u saw/heard what?
Old 02-27-2012, 06:59 AM
Emi Emi is offline
correct, and not touched until repaired
Old 02-27-2012, 07:04 AM
Zeke's Avatar
Only time will tell and with 20K now since replacement it seems you dodged a bullet. Have you done an oil analysis?
Old 02-27-2012, 10:11 AM
syncroid's Avatar
I did one on a 2000 Boxster S that had lots of metal in it. It looked like fools gold in the oil and countershaft. The customer wanted us to replace the bearing anyway. We did. Its still on the road.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 02-27-2012, 12:10 PM
syncroid's Avatar
I still have the picture of the metal.
Dan
Old 02-27-2012, 12:14 PM
You say the IMS center bolt snapped, was it an original, factory IMS? Was it replaced with the LN engineering IMS bearing?
Kurt
Old 02-27-2012, 12:37 PM
Emi Emi is offline
ims failure
Hello,
yes, the original bolt singal row bearing. However, metal not as bad as indicated. Where was that metal wiped from and how long ago was the ims replaced? Has the car covered many miles?
Old 02-27-2012, 06:19 PM
Slackerous Maximus
HardDrive's Avatar
Can the IMS bearing be replaced without cracking the case?
2014 Cayman S, PDK
Old 02-27-2012, 06:47 PM
syncroid's Avatar
We did the bearing replacement about two years ago and probably 8-10 thousand miles. The metal was wiped from the inside of the counter shaft. I can't believe the car is still running myself.
I am not recommending that anyone replace their IMS bearing with this much metal inside the engine. This guy is just really lucky...so far.
Dan
Old 02-27-2012, 06:50 PM
syncroid's Avatar
Yes
Dan
Old 02-27-2012, 06:53 PM
Emi Emi is offline
re ims failure
Hello,
Thank you for the reply, was there any metail particles in the oil itself? Did you take the oil pan down to remove the larger chunks if there were any? lastly, did this car fail with the center bolt breaking or what type of ims failure did the car have?
Regards,
Old 02-28-2012, 06:13 AM
syncroid's Avatar
Hello,
Regards,
Yes. There was metal in the oil. We did pull the pan and cleaned as best as possible. The center bolt was fine. Slight oil leak from sealing area. (pretty normal)
It came to us with a noise complaint. The bearing was loose and wobbly.
Dan
Old 02-28-2012, 07:00 AM
Emi Emi is offline
Ims failure
Wow, I lost the center bolt cracked right off and leaked out all the oil. The car ran perfect no noise ect.. Only indication was a large oil leak similar to a rear main seal failure. However, no timing was lost? This is the forth car I have heard of with similar situation?
Old 02-28-2012, 03:41 PM
