Zeke's Avatar
Originally Posted by johnco View Post
it's not a new thing... my 57 buick has lug bolts. 9/16's lug bolts
Yeah, I remember a few cars that had them besides VW's. I always thought they were retarded.
Old 05-06-2012, 09:23 AM
coulda, woulda, shoulda
johnco's Avatar
and some are right hand threads one side, left hand threads the other side
John
74 911s
Old 05-06-2012, 09:34 AM
Porsche did the Boxster like that to go back to their 914 roots
Old 05-06-2012, 09:41 AM
Now in 993 land ...
aigel's Avatar
Just rotated the wheels on my TDI doing the 40k service today. Wheel bolts - what a PITA! I came here to see if the board had any past wisdom on the reason for bolts over studs. It is what I thought ...
I want to continue to run this car on a budget, meaning maintenance and repairs only, no mods, but a stud conversion is high on the list now.
G
81 SC (sold)
Old 01-12-2014, 08:33 PM
johnco's Avatar
G
changed from lug bolts to studs on my old fiat spyder long ago when I changed to custom wheels. had a flat one night 100 miles out of town, changed it and about 50 miles closer to home that wheel passed me up doing 70 on an unlit 2 lane blacktop, jumped a canal and ended up in the swamp. 3 of the studs had stripped out when the wheels were installed with an impact wrench at the tire shop. had to drive it home with about 1/2" of rear rotor ground flat from the road and 1 lug nut tight and 1 hand tight. rotor made some pretty sparks before I finally stopped.
John
74 911s
Old 01-12-2014, 09:22 PM
I read an article in a Mercedes publication that said in their research showed bolts were more reliable and stronger. They said studs sometimes get a crack and the user will never see it until it breaks. I don't remember all the details but Mercedes thinks they are a better solution to holding on the wheels.
Old 01-13-2014, 06:29 AM
Lotus has them, I dont mint them a bit because the wheels ar hubcentric and small/light. I think my opinon would change if it had 19/335
07 Exige S
Old 01-13-2014, 06:42 AM
Did you get the memo?
onewhippedpuppy's Avatar
Try using bolts when you have spacers, as I have on my 996. Three sets of holes to align. I just picked up a threaded stud to minimize the cursing.
‘07 Mazda RX8-8
Old 01-13-2014, 06:48 AM
BReif61's Avatar
Wasn't there one in the toolkit?
-Brad
2002 Carrera2
1986 944 Turbo
Old 01-13-2014, 07:07 AM
mikesride's Avatar
22" rims on my last audi.....they provide you with a little plastic thread in dowel that broke the first time I used it.....It was pretty cold out that day but come on couldn't you at lest make it outta steel????
I've driven alot of crap to get here man!
Old 01-13-2014, 03:19 PM
You do not have permissi
john70t's Avatar
Studs use two points of attachment(m/f threads), versus one for bolts.
Old 01-13-2014, 06:16 PM
Max Sluiter
Flieger's Avatar
No, studs are pressed into the hub.
Old 01-13-2014, 06:23 PM
john70t's Avatar
Thank you.
john70t <-----fail
(and yes I've replaced them many times. mind was elsewhere)
Old 01-13-2014, 06:28 PM
Now in 993 land ...
aigel's Avatar
I can't see how they are "stronger", but I do think the crack story does make sense.
I'll get a stud in the right thread size to make it easier next time. It is the fronts that suck most, the rears have more of a hub the wheel grabs onto.
G
81 SC (sold)
Old 01-13-2014, 06:43 PM
