wdfifteen's Avatar
Need help from the brain trust - sailboats
There is a device used on sailboats and other applications that I need to describe but I can't find the name of. It is a drum, rotated by an engine. A rope is connected at one end to a crane or boom and the user wraps the other end of the rope around the drum for a few turns. When lifting a sail or cargo the user pulls on the rope, which tightens it against the drum, causing it to wind around the drum, lifting the weight by motor power. To lower the weight or control the speed of the rope the user relaxes the tension on the rope, allowing it to slip on the drum.
It differs from a windlass in that the drum always turns in the same direction and the end of the rope is not attached to the drum. What is this thing called?
Old 02-27-2013, 09:13 AM
I believe you are referring to a capstan:
Capstan (nautical) - Wikipedia, the free encyclopedia
1972 Porsche 914
2009 Mazda3
Old 02-27-2013, 09:28 AM
Parrothead member
VINMAN's Avatar
A windlass is electric or hydraulic powered powered and turns in both directions. Its also always horizontal. Most capstans on sailboats are hand cranked although there are some powered ones. Capstans are vertical.
Vinny
Old 02-27-2013, 10:00 AM
Banned
winch but there are lots of kinds/types
there was a show on old Chinese junks last weekend
that used a double drum [different sized] and counter weight
what you described is a common sailboat mast winch
they are mostly hand powered but can be motor driven on bigger boats
ether electric or hyd powered
some later square rigged ships used donkey motors [steam or later IC] to raise sails and booms
Old 02-27-2013, 10:54 AM
jmaxwell's Avatar
The same arrangement has been used in the oil fields as well, even to the extent of attaching one to the rear wheels of a truck for hoist assistance. A Capstan, for sure
Jack
'70 914/6
Old 02-27-2013, 11:01 AM
There is a term that we used to be use when I was working on marine equipment 30 years ago. The PC police won't like it being used now.
Old 02-27-2013, 11:02 AM
Banned
most windlass are used on anchors and have a chain sprocket
some have a drum used on the other side of the chain side
they can be powered by hand or electric or hyd power
but most freewheel going down as you can't get the chain to slip
Old 02-27-2013, 11:05 AM
wdfifteen's Avatar
You know exactly what I'm talking about then. I'm trying to find the PC term for it.
Old 02-27-2013, 11:12 AM
wdfifteen's Avatar
This is part of a photo from a 1909 brochure that I am going to use in a magazine article. The uh, 'item' is a drum directly connected to the engine crankshaft.
This is part of the original caption describing the item. I obviously can't use it word for word.
Old 02-27-2013, 11:16 AM
When doing subsurface sampling - the drill rig is equipped with a friction cathead - seems similar to what you are trying to describe...
Oil and Gas Well Drilling and Servicing eTool: Illustrated Glossary - Cathead
1972 Porsche 914
2009 Mazda3
Old 02-27-2013, 11:33 AM
wdfifteen's Avatar
Cathead it is. Thank you very much.
Old 02-27-2013, 11:53 AM
zotman72's Avatar
FWIW, there are no ropes on a sailboat, they are called lines. YMMV
Old 02-27-2013, 11:58 AM
crustychief's Avatar
Unless they ( lines) are made of metal.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-27-2013, 12:52 PM
Senior Advisor
James Brown's Avatar
like chow lines
08 Cayenne Turbo
Old 02-27-2013, 05:30 PM
or sheets
Old 02-27-2013, 05:43 PM
The word I was referring to is in the picture above.
Old 02-27-2013, 06:08 PM
