Need help from the brain trust - sailboats
There is a device used on sailboats and other applications that I need to describe but I can't find the name of. It is a drum, rotated by an engine. A rope is connected at one end to a crane or boom and the user wraps the other end of the rope around the drum for a few turns. When lifting a sail or cargo the user pulls on the rope, which tightens it against the drum, causing it to wind around the drum, lifting the weight by motor power. To lower the weight or control the speed of the rope the user relaxes the tension on the rope, allowing it to slip on the drum.
It differs from a windlass in that the drum always turns in the same direction and the end of the rope is not attached to the drum. What is this thing called?
1972 Porsche 914 2009 Mazda3 |
Parrothead member
A windlass is electric or hydraulic powered powered and turns in both directions. Its also always horizontal. Most capstans on sailboats are hand cranked although there are some powered ones. Capstans are vertical.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Banned
winch but there are lots of kinds/types
there was a show on old Chinese junks last weekend that used a double drum [different sized] and counter weight what you described is a common sailboat mast winch they are mostly hand powered but can be motor driven on bigger boats ether electric or hyd powered some later square rigged ships used donkey motors [steam or later IC] to raise sails and booms |
The same arrangement has been used in the oil fields as well, even to the extent of attaching one to the rear wheels of a truck for hoist assistance. A Capstan, for sure
Jack '70 914/6 Last edited by jmaxwell; 02-27-2013 at 10:06 AM.. |
There is a term that we used to be use when I was working on marine equipment 30 years ago. The PC police won't like it being used now.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Banned
most windlass are used on anchors and have a chain sprocket
some have a drum used on the other side of the chain side they can be powered by hand or electric or hyd power but most freewheel going down as you can't get the chain to slip |
You know exactly what I'm talking about then. I'm trying to find the PC term for it.
![]() This is part of a photo from a 1909 brochure that I am going to use in a magazine article. The uh, 'item' is a drum directly connected to the engine crankshaft. ![]() This is part of the original caption describing the item. I obviously can't use it word for word.
When doing subsurface sampling - the drill rig is equipped with a friction cathead - seems similar to what you are trying to describe...
Oil and Gas Well Drilling and Servicing eTool: Illustrated Glossary - Cathead
Cathead it is. Thank you very much.
FWIW, there are no ropes on a sailboat, they are called lines. YMMV
Unless they ( lines) are made of metal.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Senior Advisor
like chow lines
08 Cayenne Turbo |
or sheets
The word I was referring to is in the picture above.
