Tire question- at what point do you buy 2 new tires when 1 needs replacing?
Hello,
I just got a screw in the sidewall of one of my run-flat tires (read $$$) that cannot be fixed, so I need to get a new tire. The tires have about 18K miles are probably at 50% use.
At what point would you get two new tires instead of just one? Car isn't 4 wheel drive, so I am not too worried about one tire having a slightly larger rolling diameter than the others.
Thanks,
Neil
Neil
'73 911S targa
Old 01-27-2014, 07:53 AM
At 50% wear I would replace both, 1 so you don't get pull left to right, 50% isn't great but not bad so it is has served you.by the time it is worn out your other tire ( the 1 new one you haven't bought yet) will be 50% worn out and you will be in the same place you would be now with a mismatch set of tires. And Peace of mind. But if flat tires are common for you that may sway your decision. Just my thoughts
Old 01-27-2014, 08:32 AM
depends on the car and the application. If its for a comuter car, id consider replacing just one.
However I think the real answer is to find a more moderately priced set of tires, and get a AAA plan for towing.
18 Cayman GTS
Old 01-27-2014, 08:55 AM
recycled sixtie's Avatar
Just did that on my 2001 Boxster two months ago. Flat rear snow tire and did not drive long on it(old Blizzak) but damaged the sidewall beyond repair. Bought 2 new Pirelli snow tires for the rear. Happy I replaced both.
When it comes to safety I do not compromise.
Old 01-27-2014, 09:10 AM
one of gods prototypes
bell's Avatar
Replace both, store the good slightly worn one (you don't want it to dry rot ) in case you have a problem down the road......
Old 01-27-2014, 09:18 AM
Did you get the memo?
onewhippedpuppy's Avatar
This right here. I never understand why people are willing to skimp on tires. I don't know if there's another single item on a car that more influences performance, comfort, and safety than your tires.
‘07 Mazda RX8-8
Old 01-27-2014, 09:35 AM
canna change law physics
red-beard's Avatar
My wife's X5 has had 2 replaced because of nails in the sidewall. I purchased the "spare tire kit" for her car and will be changing to standard tires when these are done.
James
Red-beard for President, 2020
Old 01-27-2014, 09:46 AM
Bill Douglas's Avatar
Always replace both. If they are on the drive end of the car the diff/transaxel will be constantly working because of the different circumfrences (spelling?) A friends BMW threw up warning lights all over the place because he had a worn spare on the front so the car. Half of the cars computing thought the car was turning because of more rotations on one side, and the other half of the computing said not, so it said problems goto sickbay.
Old 01-27-2014, 11:13 AM
No two tires will ever be the exact same circumference. Brand new sets of tires are not the exact same circumference.
Tires are manufactured to be within a tolerance of the same circumference, and they start wearing unevenly as soon as you drive them.
I buy used tires on eBay and Craigslist all the time. Look for tread wear that is close to what you need to "match".
Bollocks to the tire salesmen who say you need to buy in matched sets.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 01-27-2014, 11:23 AM
wdfifteen's Avatar
Buy 2 new tires and keep the good old one. You never know when you may need it to match up another half-worn tire.
Old 01-27-2014, 11:29 AM
Control Group
Tobra's Avatar
If I had a nail in one of the run flat tires on pretty much any vehicle, I would be buying 4 tires. Actually, I don't think I would drive off the lot on run flat tires if I were to purchase a car wearing them.
In your case, buy two, store the good one, as suggested above
Old 01-27-2014, 11:30 AM
My wife shredded a tire on the highway in her nearly brand new F150 after hitting a piece of metal. That's the only excuse I needed to replace all four of the crap Goodyears.
‘07 Mazda RX8-8
Old 01-27-2014, 11:43 AM
AutoBahned
RWebb's Avatar
one problem is if you store the new tire (in the dark, under nitrogen, whatever) for 6 years and never use it, the tire is still dangerous to mount and use
if you cannot bring yourself to buy 2 new tires and it is an in town car only or low speed car, then buy one matching tire and have it shaved to the exact tread depth of the opposite tire
Old 01-27-2014, 12:43 PM
porwolf's Avatar
Happened to me: Screw in the sidewall of my '79SC pretty new rear wheel. Could not get a new replacement of the same type and size (Pirelly P-Zero Nero All Seasons) because they don't sell my size anymore. For new tires, to do it right, I would have to replace all 4 tires. I found a used tire here on Pelican, same make and size, with about the same wear and age. It's on my car now. No problems.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 01-27-2014, 01:43 PM
wdfifteen's Avatar
How do people get nails and screws in the sidewalls of their tires?
Old 01-27-2014, 02:31 PM
porwolf's Avatar
In my case the screw was just outside the running surface. The tire repair shop refused to patch it because of new liability issues. I understand if the puncturing bit is not located exactly inside the running surface a responsible tire shop will not patch the tire anymore. At least not here in California.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 01-27-2014, 03:18 PM
Just thinking out loud
mattdavis11's Avatar
I usually get two new ones in that scenario and move the best to the spare.
91 FJ80
84 Ram Charger (now gone)
Old 01-27-2014, 03:52 PM
could you replace all four with regular tires?
Old 01-27-2014, 04:03 PM
Buy a used tire?
Old 01-27-2014, 04:11 PM
It seems like 185/70/15 is not a common size.
What sort of "every day" commuter tires do you guys run?
Old 01-27-2014, 04:16 PM
