Bill Douglas's Avatar
I need your help.
I'm trying to fix the light switch on the 911 to sort out the high beam/low beam problem. But it's going from bad to worse
Umm, the owners manual says the low beam is to the steering wheel and high towards the dash. Is this correct?
I have fixed it in the past but this time things are going a bit weird. Around here we have to get a Warrant of Fitness every six months which is much the same as a MOT that they have in Britain. And it's been expired for over a month which is risking a $300 fine. So I need to fix it.
Thanks.
Old 02-09-2015, 10:16 PM
WPOZZZ's Avatar
Try this. turn signal switch quick fix pictures
Old 02-09-2015, 10:23 PM
Banned
Thanks.
Yes, that is the correct switch operation. Wouldn't this question be better asked in the tech forum? I don't care, really, just curious.
Thanks Brian. Great thread. That should do the trick. I'm going from bad to worse with this minor job so pics sure will help
I should thanks Eric, I'm just used to posting on this forum. The other one is unknown waters to me.
Old 02-09-2015, 10:52 PM
DanielDudley's Avatar
Going for a new switch and a relay set would be a reasonable solution, if you have gotten your money's worth out of this assembly.
If it is to be a case of sooner or later, why not sooner ?
Old 02-10-2015, 01:26 AM
Did you get the memo?
onewhippedpuppy's Avatar
The old switches for high/low are just a metal tang that touches one of two contacts depending on switch position. They can get out of whack but really don't "go bad". You just adjust them by bending the tang.
‘07 Mazda RX8-8
Old 02-10-2015, 04:05 AM
I rebuilt my old switch several times. I finally just replaced it and put in a headlight relay kit. If you don't have the relay kit, get one. Do a search in he tech forum for the relay kit. One of the members sells a complete kit that is easy to install. That will fix your headlight problem permanently.
Old 02-10-2015, 05:23 AM
durn for'ner
livi's Avatar
Ah a good old Tech thread!
Hope it works out.
Markus
Resident Fluffer
Carrera '85
Old 02-10-2015, 06:29 AM
