Where can I find a screw this size?
Ok worlds greatest group of know it all's. Where can I locate a flat head, slotted, stainless steel wood screw with the following measurements?
Head diameter .735" diameter
Shank diameter .375"
4" in length
Thanks in advance for any help.
Old 07-17-2015, 02:15 PM
MBAtarga's Avatar
That's a #24 x 4 screw. BIG!
https://www.fastenal.com/products/details/1130340
Edit - Link is for zinc. Not sure about stainless.
Mark
'83 SC Targa - since 5/5/2001
Old 07-17-2015, 02:27 PM
Registered Cruiser
jorian's Avatar
Google "fastners" and send the the info.
Here's what I found for NJ.
Fasteners in Northern New Jersey (NJ) on ThomasNet.com
Is it stainless?
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 07-17-2015, 02:29 PM
least common denominator
scottmandue's Avatar
Our Home Depot might have those (no help to you I know)...
Might have better luck trying a marine hardware store.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 07-17-2015, 02:31 PM
Control Group
Tobra's Avatar
+1 on the marine hardware for SS
Old 07-17-2015, 02:54 PM
Thanks Guys,
MBAtarga- That's the size but it's not Stainless.
Jorian- Yes it's stainless, but I would settle for chrome plated bronze at this point.
Scottmandue- I have tried the marine and most hardware stores. The largest most carry is a size #14, I have found a #18 this as MBAtarga pointed out is #24. The closest thing I have been able to locate so far is a 3/8"x4" Stainless machine screw. With the advent of fiberglass boats and back plating to fasten hardware a wood screw this size isn't very common any longer.
Old 07-17-2015, 02:57 PM
Evolved
Mo_Gearhead's Avatar
1. Drive to the Supermax prison in Florence, Colorado.
2. Take along stainless steel bar and a file.
3. Ask for visitation to see - Ted Kaczynski.
Only need the ONE? Pfffft, he should have that done in...three ...maybe four weeks tops.
Don't fear the reaper.
Old 07-17-2015, 03:50 PM
Got a bunch of old dildos you want to get rid of?
Old 07-17-2015, 03:58 PM
I need a screw not a bung
Old 07-17-2015, 04:42 PM
Registered Cruiser
jorian's Avatar
I have a pretty big collection of stainless on the boat. Heading there tonight. I'll post up if I have one.
Old 07-17-2015, 05:01 PM
Thanks Jorian
Old 07-17-2015, 06:12 PM
Worst case, would you settle for bronze?
Jamestown Distributors
#24 Flat Head Slotted Bronze Wood Screws
Old 07-17-2015, 06:37 PM
Tacoma Screw has #24x3 stainless phillips head
[URL="http://www.tacomascrew.com/s.nl/it.A/id.24448/.f"]
Old 07-17-2015, 06:42 PM
Platinum Member
dad911's Avatar
What is the application? Can you run a modern screw or glue& dowel in the hole first, then glue the head of the broken screw back in the countersink?
Old 07-17-2015, 06:57 PM
DeanP,
Bronze is my fall back option. I will have the slotted bronze screw chrome plated if I can not find a stainless screw. I spoke to Tacoma screw today. Tacoma has a #24x4 Stainless Phillips I can use as an interim fix, they are looking into a slotted head.
Dad911- The screw holds down a cleat on my boat. I really can not go down in size. The head of the screw is also large than a modern #24 but that I can live with.
Here's a photo of the damaged screw.
Old 07-17-2015, 07:25 PM
Bland
unclebilly's Avatar
McMaster Carr or spaenaur.
Old 07-17-2015, 08:03 PM
Registered Cruiser
jorian's Avatar
I checked out my supply on the boat and didn't find anything for you. Sorry. Hope you find what you need.
Old 07-18-2015, 10:04 PM
If you were around here, I would suggest this place:
MidStates Bolt & Screw
They may be able to steer you to someone local to you if you contact them.
Mike
Old 07-19-2015, 05:38 AM
If you can get access to the inside area wouldn't you be better off using a longer bolt with a washer and nut? Bolt right thru the backing plate.
Old 07-19-2015, 06:06 AM
Thanks for trying.
Old 07-20-2015, 12:27 PM
