Talk me out of it...
![]() 1972 Porsche 914 widebody w/ Subaru EZ - $9800 (Fairfield) Up forsale is my custom 1972 Porsche 914 with a full Rayco widebody kit and a EZ30R 3.0L H6 subaru motor. This car has been great to me, but i bought another car, so now this one just takes up space and i dont have time for it. The engine start ups and the transmission goes into every gear and works as it should, no weird sounds or mechanical problems. This car was built for the intention of track racing, but i went ahead and got it registered to drive on the street which was easy because the car is SMOG EXEMPT! Engine: Subaru EZ30R Japanese pull out motor H6 3.0L Flat Six 24V with 55k miles 242 hp at 6600 rpm 219 lb-ft at 4200 rpm Radiator located to the front of the car with custom hardlines and twin cooling fans stand alone EMS ECU One off custom headers Dual Magnaflow mufflers Drivetrain and Suspension: 1st gen Subaru WRX 2.5 turbo trans with a rear diff lockout New Wilwood adjustable hydraulic clutch master cylinder new clutch (very firm) Custom shift linkage and shifter housing. One off completely custom 930 axles custom made and works perfect. Rated for 800whp.. Custom fabricated rear subframe/engine cradle made out of stainless steal and goes all the way through the middle underneath the car to stiffen the chassis New Bilstien struts at all 4 corners makes it handle a lot better and i have an adjustable coil over conversion for these struts but havent installed them. New steel braided brake likes with speed bleeders Interior/Exterior: Rare Rayco widebody professionally aligned and bonded to the body Brand new factory rubber seal kit complete and unopened all glass is intact (no cracks) Trackspec hood louvre Brand new oem tail lights and 944 running lights/blinkers. 5 point bolt in or weld in roll cage 5 point racing harness NRG Quick release steering wheel. Monster tach Auto meter gauges STR 17x9 +20 wheels on 4x100 adapters so you wheel selection is huge I had a friend at 914sgonewild make me custom the 914/subie and 930 to 914 conversion hubs. So even the axles are now an interchangeable item rather than a hybrid conversion axle. Basically this whole car is custom as hell. Every part is a one off, but I've made sure back ups will be available or be able to be replicated. I just don't have anymore time to build it.. It needs a lot of of finishing butall the hardworkis done. This is the only car like it that exists and it starts, runs and drives perfect. Oh and no rust. The car is very clean! Most of it has been rubber-ized and under coated to protect and prevent from rust. serious buyers only please. might consider DECENT trade offers. Call or text Brian. show contact info anytime. If I don't answer text me. Swap swapped project 914 914-6 hybrid subie suby Subaru custom rare fast mid engine Porsche track car H6 EZ30 EZ30D EZ30R 1972 Porsche 914 widebody w/ Subaru EZ
76' 911s Signature Edition |
If that was done with great talent and care, go for it.
If it was built by a hack that thinks JB Weld is the cure for everything RUN.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Somewhere in the Midwest
Doesn't look like a hack job and he was honest about needing to address the fit and finish. If I was in the market I'd consider it...the drivetrain would be great for a 550 Spyder if you get tired of the 914 bod. Or sell it later to someone building a 550!
Sorry didn't try to talk you out of it
Did you get the memo?
Saw that on BaT, do it!
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Not my cup of tea...I prefer as original as possible.
Don't do it, Enzo!
Old dog....new tricks..... |
It's built correctly. No issues of blowing up a 905, or 915...
Check for rust as usual with 914's. Is it 5 lug conversion yet? Doesn't sound like it. Make sure it doesn't over heat. A turbo will be next for that car.
dolor et pavor Copyright |
resident samsquamch
Gotta echo this! Can't talk you out of this one, if it checks out. Looks like fun!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
canna change law physics
If a 914 is NARP, what the hell is that !?!
I don't mind the body kit. And as long as the build quality is good, the price is pretty killer. Road glue plus.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Looks like a lot of fun. Only way I'd talk you out of it is if I could talk the wife into it
Guy '87 944 (first porsche/project car) |
i dated this girl. her mom use to ask me this question on occasion. it is fitting here;
"what are you, meshuggenah?!!"
poof! gone |
Now in 993 land ...
Water cooled - and the body looks like garbage. Not 10k worth to me. $5k tops.
I'd drive a 914-6 of the air cooled variety ... G |
For something turn key, race ready "if the cage is legal". I think that's a fair deal.
No way you could build it for that money. You need to drive it, and don't be too slow.
