New Question on Floor Prep for Epoxy
Got a question on Floor Prep - before Epoxy
Painting took longer than expected so I haven't got any of my floor prep started. Now the weekend is here and I was planning on renting a cement resurfacer.
Question: does it matter "when" I surface the cement. I.e., I haven't degreased yet, can I do this after the resurfacing or should I degrease first. I want to take advantage of the weekend to resurface the concrete so I'm hoping I can do this tomorrow and then spend next week degreasing, pressurewashing, etc..
Old 09-22-2017, 08:28 AM
Navin Johnson
TimT's Avatar
Degrease first, lest you redistribute all the grease while grinding the surface.
After you finish all your prep, take a 1 foot square of poly and tape it down with duct tape... leave overnight.... if the next day there is moisture trapped under the poly, rethink the coating you want to apply... sealer or stain might be better than epoxy, if there is a lot of moisture..
'69 911 GT-5
'75 914 GT-3
and others
Old 09-22-2017, 02:46 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Meh. I say no. Just me. Not arguing.
Beat the shiet out of the floor. Get it down to a nub. Powerwash like a fiend.
1981 911SC Targa
Old 09-22-2017, 03:30 PM
Don't do it...
I did, and 2-3 years started peeling off... Good luck fixing it...
If ANY water gets in behind it, from condensation or rain, etc, it will not stick...
Old 09-22-2017, 04:45 PM
Navin Johnson
TimT's Avatar
Sure recommend doing it wrong...thats good advice..
Surface prep is key for the success of any coating system... cleaning and degreasing are first.. often followed by chloride remediation (if on steel surfaces) then surface prep by creating a profile..
Those pesky organizations that set standard for paints and coatings are where the procedures come from.... NACE... SSPC... ASTM...
Oh and wow... here is a guide from the manufacturer of one of the epoxy floor coatings...
Epoxy Coat Installation Instructions
Step 1: Clean and Sweep
Step 2: Degrease...
Or you could just smear that grease and oil around and have the coating come up...
'69 911 GT-5
'75 914 GT-3
and others
Old 09-22-2017, 04:58 PM
I gotta agree with TimT on this one
Old 09-22-2017, 05:41 PM
Brew Master
cabmandone's Avatar
Clean and degrease first. Then grind the floor.
Old 09-23-2017, 03:17 AM
Clean and degrease it first, then shot blast it.
But, we covered that in your other thread...
Someone also mentioned testing for water migration through the slab. That should've been done long before you decided to put epoxy down on the floor.
Old 09-23-2017, 04:30 AM
Registered Abuser
MT930's Avatar
Just had one done by the pros they cleaned degreased. Ground -fillled cracks re ground. Epoxyed then put a poly urethane UV coating on top. Lots of grinding.
I would try it but the grinding is the key. This guy used some specialized grinder with a big vac I have no idea where you could rent one.
I have seen a lot of hanger floors done with success and failure.
The grind gives the profile that the epoxy can grip. Any oil or dirt the epoxy will lift.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 10-01-2017, 08:56 PM
