GWN7's Avatar
Saw this in a garage with over $1,000,000 worth of Porsches in it. Reflects the light making almost no shadow zones.
If I ever build another garage it is how I will go.
Corrugated metal
Bunch of old cars
Old 01-05-2018, 04:39 AM
rfuerst911sc's Avatar
Corrugated metal
I had a metal ceiling ( white ) in my last garage and will be adding a metal ceiling ( white ) in the new man cave I'm building . I think the white reflects the light very well and looks a little less commercial/industrial than the galvanized . But I am going with a 42 " tall galvanized wainscote to add a little bit of pop at the bottom of the walls .
Old 01-05-2018, 05:15 AM
My clients used that stuff in their tanning salon walls 20 years ago, I won a local AIA award for it, the metal hallway walls were a part of it. The owners (did some of their own work and were excellent collaborators on the design) said they tried it directly over the studs but it didn't come out right, so they ended up installing it over drywall. This was the thin somewhat decorative stuff, but not the thinnest available.
Looked up other uses, looks like you can do a ceiling.
https://www.youtube.com/watch?v=aPPbs0OHK84
I'd have to check the code on what they did in that house video, last time I checked metal transfers heat too quickly (in case of fire) which is why the code encourages drywall over any other material when it comes to walls and ceilings. Even exposed CDX board inside of homes is highly discouraged in the code. And what I mean is you have to read between the lines sometimes, and it always comes down to your particular inspector. Just because you saw a picture or video on the Internet doesn't mean you can get away with it too.
I know what your are thinking, but this is a detached garage. Well, if you have insulation and an inspector involved be prepared to argue against meeting a higher standard, have a Plan-B and a prepared case statement with code citations.
Old 01-05-2018, 05:20 AM
Puny Bird
Mark Henry's Avatar
Mark- by roofing panels do you mean the "5-V" sheetmetal panels like used for a barn roof?
Yes
Originally Posted by VincentVega View Post
What do you do when you want to get into the wall to add/or change some wiring? Drywall might not the the strongest but it patches really simply. That said, I had a few dents but nothing out of place in a shop.
Metal remove the screws and a whole 36" x 8' (etc) panel can be removed.
When using metal on the walls is all the electrical surface mounted?
Seems like a PITA having to cut the metal for your electrical boxes for switches/outlets.
Actually it's not that bad, screw gun with a step drill bit and a pair of tin snips. Most of my shop is done this way outlet every 8', care has to be taken that you outlet doesn't land on a rib. Finish off with industrial metal outlet covers.
Conduit works well if you are ok with the industrial look, I have both surface mount and conduit in my shop. Surface mount on all the original wiring and conduit on my lift, welder, lathe, etc.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-05-2018, 05:39 AM
Did you get the memo?
onewhippedpuppy's Avatar
I really like that galvanized wainscot. That would do a nice job of reflecting light down low where you typically need it.
‘07 Mazda RX8-8
Old 01-05-2018, 08:35 AM
There was a time in our youth when we talked about putting mirrors on the ceiling over our beds to see what we're doing.
Now we think it's cool to install sheet metal on the walls to see what we're doing.
Wow, getttin' old sucks...
Old 01-05-2018, 10:54 AM
The only problem is, it's hard to convince my wife to join me on the garage floor.
‘07 Mazda RX8-8
Old 01-05-2018, 11:30 AM
Information Overloader
Then aks somebody else, Matt.
Old 01-05-2018, 12:50 PM
redstrosekNic's Avatar
Originally Posted by cabmando View Post
I take the screws out of the OSB, remove the panel, add or change and put the panel back in.
Yes, this is another thing I like about it!
Dustin
Old 01-05-2018, 05:07 PM
My garage is unfinished and I have a thermometer out there, the temp ranges from 20 in the winter to 100 in the summer. My OSB is butted together and it is totally fine.
Good to know... I will probably end up butting the panels together. All the suggestions say to space them, but it seems most people install them tight. Should make for an easier install.
Dustin
Old 01-05-2018, 05:10 PM
Platinum Member
dad911's Avatar
The OSB doesn't move. Much more stable than the studs it's attached to. New construction with bearing walls, even with the KD Dry studs we use, the studs and joists shrink a little. So it's gapped about 1/8 (10d nail) If the OSB was tight on a bearing wall, new construction, it could be a problem.
If your framing is older, it's settled out and dry, likely would not be a problem.
If it's new, I'd leave a 1/4 to 3/8 gap top and bottom and cover it with a little trim.
Old 01-05-2018, 05:25 PM
The garage is a few years old, so not sure if that is considered older. Is the gap on the bottom of the wall all that matters, or should I leave one all around each board?
Dustin
Old 01-05-2018, 05:57 PM
Yes. Be sure to measure and weigh each fastener, too. Sometimes you get a short one.
Old 01-05-2018, 06:00 PM
She also wouldn't be fond of that plan.
‘07 Mazda RX8-8
Old 01-06-2018, 03:52 AM
Yeah, so?
Don't tell her. The wet spot wil blend right in like where most 911's park.
Old 01-06-2018, 05:37 AM
Platinum Member
dad911's Avatar
I wouldn't worry about it then.
Old 01-06-2018, 12:25 PM
