Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Slumlord
Porsche_monkey's Avatar
Project Zeke - Part II
Some of you may have read my thread in the 911 forum, this is the (hopefully) final push to finish the car off.
Body Guys - I Need Help
I started off with this:
And after months (I really don't want to add up the hours) I'm here now:
Aligned, primed and (almost) ready for paint. This is the bodywork equivalent to 'while you're in there'. I have stripped every piece of trim and panel off the car, the glass is out, and every spec of rust (yes, there were few spots) has been cleaned up.
I water sanded (400 grit, then 600) the entire car. Primed it and resanded.
A few 'issues' popped up....and were filled and need sanding/repriming:
The standard Porsche door crack was tig welded but still visible, body filler was added today:
Gravity feed paint gun:
Paint & Filler
Sanding tools:
Advice I can offer at this point:
The Valspar pimer filler is very good, easy top apply and sands niceyl. It does have a tendancy to 'orange peel', which can be sanded out. I will balme that on the painters inexperience not the product.
The body filler was a problem until I put in the paint shaker. It needed a good stir. It also went on much better when I thin it slightly with laquer thinner.
I wet sand everything, except my first rough pass on the bondo. Water is your friend when when wet-sanding, keep a pray bottle or hose handy to remove the waste.
Finally: I will never ever question the price of a paint job from a body shop. The amount of work required to do this properly is astounding.
I've done the painting so far, it's time for a pro to help me out with the base and clear. I'll update this as we move along. Slowly but surely.
Old 05-22-2008, 12:15 PM
abit off center
cgarr's Avatar
Cant wait, I will be painting mine this weekend, black also..
______________________
Craig
G2Performance
Old 05-22-2008, 12:23 PM
Slumlord
Have you picked a paint and clear-coat product yet?
Old 05-22-2008, 12:40 PM
abit off center
cgarr's Avatar
I am going with a single stage off the shelf black
Craig
G2Performance
Old 05-22-2008, 12:43 PM
Slumlord
Chicken.
Old 05-22-2008, 12:47 PM
abit off center
cgarr's Avatar
Originally Posted by PBH View Post
Chicken.
I will loose points at the Concours d'Elegance competition if I change from the factory system
Craig
G2Performance
Old 05-22-2008, 12:58 PM
Good luck, post some pictures when you're done.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 05-23-2008, 07:33 AM
Slumlord
Several months later I have accomplished a few things:
1) sent my daughter back to University
2) ditto for son
So, now that I have some time.....
Top coat #1 with pricey DuPont paint...
Using this stuff at over $150 per quart:
And then water sanding with 800 and 1000 grit before the second coat:
Still a ways to go. But I'm getting there....
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 09-08-2008, 12:43 PM
SCWDP911's Avatar
anything new?
Shane
- 1984 928S
Old 10-20-2008, 08:24 PM
Slumlord
Yes. And no.
Education is expensive, so take the benefit of my time and money:
1. You do not know how to paint a car if you've never done it before. You only think you know.
2. An old car has a lot of dings and nicks you never saw until it is painted.
3. Black shows every flaw, see 2. above.
Having said this...
Removable bits have one coat of base, are water sanded and ready for top coating:
The fender had a 'bad reaction' in one spot, I am assuming I missed a spot with the primer, which allowed the new base to contact the old paint, and produced an instant wrinkle finish. So this was re-primed and wet-sanding is almost done:
And the body is primed but needs lots of water-sanding since I didn't put on quite enough paint. No flow means a rougher finish which means more sanding. So few days at this...
And I'll be adding basecoat #1 to the body.
84 Cab - sold!
Old 10-21-2008, 02:48 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
It's looking good! It's too bad you're so cramped in that small space to work.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 10-21-2008, 03:11 PM
Slumlord
Crap accumulates to fill any voids. Just give me time...
84 Cab - sold!
Old 10-21-2008, 03:12 PM
Happiest when Tinkering
gsmith660's Avatar
I used dupont chromasystem and that is why I only did bodywork I had someone who knew what they were doing lay on the paint my paint only totals were around 1000 dollars, and it went on nice.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 10-21-2008, 04:21 PM
19 years and 17k posts...
azasadny's Avatar
Incredible work! I admire you guys who bring these cars back to life!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-21-2008, 05:10 PM
Slumlord
Call me a suck if you want but I chickened out and took my car to a painter.
I am losing my workspace shortly, and given the price of paint and clearcoat it seemed crazy to move forward on the assumption i could do a high quality paint job on my first try.
The car is back (most of it is). Just re-assembly is left.
84 Cab - sold!
Old 12-18-2008, 12:12 PM
You arent going to wet sand and polish? Be a huge mistake at this point.
JP
'76 911s Ice Green Metallic bone stock
Old 12-24-2008, 09:41 AM
Slumlord
That's been done once. He wants to finish off with a finer compound when the clear coat has hardened more.
84 Cab - sold!
Old 12-24-2008, 10:29 AM
Where is the update to this awesome story?
Old 09-17-2009, 03:33 PM
