Registered speed offender
78-911SC,
If you are referring to the door jam, it was somewhat difficult. What I did is hang the the door after I thought I had things close. As far as trial fitting there was a LOT of back and forth between clamping it in place to check fitment and the bench grinder. Once I got it how I wanted, I clamped it in place and made a few strategic welds and rechecked the door alignment just to be sure. Then it was just weld and grind. The piece in the most recent post was surprisingly easy. Since there was only one edge to butt, once prepped, (prep took way longer than fitting) it was really only one trial fit (a tap here and there with a big hammer to get it lined up) to mark the cut for the butt weld. I got it right the first time so no big deal.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
Not exactly. I was referring to the piece in the first picture of your post. The black piece just after the gray wheel well. The fender mounts to it just before the door opening. I'm getting ready to do mine and not sure how you got it exact. Thanks
PJ 78 911sc Targa 70 911T |
Oh yes,
The previous owner did that. Not sure what he did but... I would use a sharpie to mark the metal on both sides of the old panel before you remove it. That way you have a point of reference. BTW, there really is no such thing as exact. When you get to the point of putting your fender back on, you can make adjustments with washers as spacers where the screws are. If need be, you can pull or bend it the other direction. When you go to weld the new panel, you can weld the drilled holes from inside the car. I'm sure you figured that out by now. To get the panel to stay in place, you can tack it from the outside. Also you can drill some small holes and use sheet metal screws to suck it up to the body more while you weld. The new panel may need a little help from a hammer too. ![]() Like I said, nothing is perfect on these cars (except the engine of course) Don't be afraid to cut and grind a little if necessary. Good Luck, Derek
Pictured is the new wheel house/bumper bracket welded in. Circled in red is the piece I had to make... it doesn't look like much but it took some time to make using different hammers and a little heat from the torch.
![]() ![]() Ah Jees, more friggin rust. This isn't the best place to find it either. Luckily it was just a small spot. Notice the strip I cut and welded back up. That was so my mirror would fit inside to check for more but there was none. Whew!
I can hardly believe it but I think I'm done with the rust repairs. I have a few more house keeping type things to do before it goes to the media blaster. I won't know what to do with my spare time now... anyway I will be switching gears, so-to-speak, to get ready for epoxy primer and body work. By just a quick look at the car, you really wouldn't know how much work has been done being as it looks basically the same as when I brought it home. Needless to say I'm very anxious to have it all cleaned up and back to one color... and minus the rust!
Here's something only slightly more interesting than panel repair. I welded the holes closed that were left by the overweight factory flag mirrors and did a trial fit of my new Talbot mirror.
Holy crap, this is awesome stuff. You've gotten a lot done in a pretty short stretch of time, my friend. And props to your welding skills. Way better than I can do. Plus I don't have a welder, which is a big help when you're trying to weld.
Sorry if I missed it earlier in the thread, but when's the big date with the blaster? Also, call me a traditionalist, but I'm not so sure about the mirrors. I have to admit I love the 70s/80s chic of the rectangle flags. Though I suppose you're going way retro, so...You mentioned offline you are getting some Yellow Bird bumpers - which I think rock and I've considered getting some too - so maybe you should try to track down one of these to complete the YB look: ![]() The passenger door is sans mirror. Shaved, if you will.
-Troy 88 3.4L Coupe |
No date with the blaster yet. I've spoken to the owner (Master Blaster) a couple times. I am ready for it except for the oil cooler duct I mentioned. I need to wait till probably May for temp reasons. The primer needs mid 50's, which we are getting now but only during the day for a couple hours. I want to shoot it as soon after as possible to avoid any flash rust. I'm turning my garage into a giant spray booth.
Neighbors have been warned ![]() I'm with you on the mirror and I lost some sleep (weird) trying to figure out what to do with it. I even thought about the longhood option for awhile. The PO gave me some of those (935?) mirrors with the car but the quality just wasn't there so I sold em'. I'm not sure how it's all going to tie together but yes, a bit of a retro look, I even got some (gulp) chrome H4 sugar scoops. So it's going to be a sort of American style hotrod, retro thing of sorts. I expect there will be some who don't approve but like I said, I'm not trying to copy any particular model. Thanks for the welding props. I tell you, those auto darkening welding shields can make anyone a decent welder. Here's a photo of the bumper I ordered: I hope Ed doesn't mind.
That is awesome. I dig the YB bumpers. They sure save can save some weight too. Just the bumper shocks for the accordions are like 50lbs for all 4 corners.
And if you've got visions of track days in your future (and I hope you do), the brake ducts might be more useful than fogs. I have 993 air scoops on my lower control arms and they make a pretty significant difference at the track. Between those and using Motul fluid I've pretty much eliminated my brake heat issues, even at Pacific Raceways which is hell on brakes. And the scoops have to be the cheapest Porsche part ever at less than 15 bones each. They would probably work even better if I installed the hub block-off plates that I have had in my parts bins for the last 3 years. ![]() That reminds me, not to put the cart too far in front of the horse, but did you figure out your plans the motor?
Almost Banned Once
You car is looking great. Well done on the rust repairs.
Viper Green???
- Peter |
Oh Boy... I had another brain hemorrhage and switched my order to my original bumper choice of the IROC RSR style for the SC flairs of course. I just couldn't see the car with all of the bright work of an early car and the bumpers of a car some 12 years newer. It should be more period correct this way.
I would def. be interested in a track day once it's all said and done. I'll most likely need to head over the hill since the measily track we have here, well, can you say S U C K S? On an update note: I dropped off my metal grill for polishing yesterday (ouch) and started the install of the front oil cooler ducting. I just want to say this about that... I got the duct that TRE makes from Elephant and I must say if you're thinking of doing this, just make your own... It really doesn't fit. For starters it's 27" wide. The widest Setrab you can get is 22.5" Basically, by the time you get it installed you'll have made your own. I'll post some pics when done. (Maybe on an earlier car it fits better?) Thanks for all the cuddos on the welds. I've done so much now it seems almost easy. (I just bought a new weld helmet from, gulp, Harbor Freight and I have to say, I like it better than the $200 one my neighbor let me use for most of the winter... and the best part is, it was only $40! As far as the motor goes... my dream machine is gonna have to be either a 3.0 or 3.2 with SSI's, PMO carbs, Cams, JE's and possibly twin plugs along with hike in compression and bore size. Like I said though, "dream" Reality may take hold, we'll see. Seriously though, we're talkin a couple years here at least. This WILL be ready for paint this fall for sure... I have all the stuff for that. The paint is gonna cost me so it might have to wait til' spring of next year. I'm doing it myself but need a new gun for the base and clear and I want to take my time with the primer coats. Oh, and I have to work too. I am still married... so far.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html Last edited by 78SCRSMAN; 04-24-2010 at 07:07 PM.. |
Well, it's still going to be cool no matter what you're choice of bumpers. Plus, I totally agree on going consistent in terms of period on a car. The Frankenporsches just never seem right, and from what I have seen, never sell either when it's time to move on to something else.
I'll be eagerly watching your progress. P.S. I have some other news too, I'll send you a message offline.
OK Troy, I hope it's the good kind.
Todays progress: I got the oil cooler duct welded in. I still need to weld in some sort of tube in front and some mounting brackets for the cooler. The tube is for strength. I'm not sure its needed but there is a tube (sheet metal welded together creating a hollow section) in the very front of the tub that had to be cut in order to fit the duct. I will source some tubing and weld it between the front corners of the duct. ![]() ![]() ![]()
Final Oil Cooler setup (Gaaaad I hope I did it right!)
This is more paint that bodywork. Here is a hand painted center cap for my wheels. It hasn't been clear coated yet but you get the idea. I'll put up a photo of the wheels when they are done.
Here's what I've been working on while I wait for the weather to improve... drum roll...
I'm kinda breaking the mold here with these wheels but I like em! Here's what I started with, ugh! The one in front is after 2 hrs of cleaning and sanding! ![]() ![]() Those of you that have done this know what I mean when I say "never again!" This took many, many hours to complete... I'm glad they're finished. The center caps are hand painted by yours truly using automotive base coat paint (I have LOTS left over if anyone wants to try their hand) and finished off with a clear coat. Each cap took me about 3 hrs each. I would estimate I have about 8 hrs in each wheel spread out over several days/weeks. Enjoy! ![]() ![]() ![]() ![]()
Updates coming soon... the tub, fenders, and doors were delivered to the media blaster Today! I also have the new IROC style front and rear bumpers for narrow (SC flared) body cars on hand. I have decided to go with OE sport seats and have taken delivery of a set... very nice, I must say. I swear the theme song from Ferris Buelers Day Off started playing when I sat in them, even though they need some new skins. Oh yes, I almost forgot, I got my earlier metal engine grill back from the polisher dude. It looks OK too.
I'll take some photos next week when the car comes home.
Hey guys... it's back from the blaster dude! All one color now... finally!!!
I've got some undercoating to remove here and there and some more metal repairs to make as you can see from the pictures. Now that I've got a better look at what the PO did (POR15) in regards to some patchwork repairs (front end) I've decided to source some good metal from a donor and replace the upper longitudinals near where the fenders mount and including the front bumper mounts. As you can see from the pics, there are some very thin areas and a few holes. Overall it turned out great and didn't break the bank. One thing to note... blasting with plastic does NOT remove the factory galvanizing. I was told it would but not true. Using sand can but not if you are careful. ![]() ![]() ![]() ![]()
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html Last edited by 78SCRSMAN; 04-24-2010 at 08:33 AM.. |
A few more...
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
that's one hell of a project you've got there Derek! Glad to see it come together and that parts of my parts car continue to live on to save others
![]() great metalworking skills as well!
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Thanks Jeff,
As I stated in my last email to you after you sent parts. I FOUND MORE RUST! I was blowing out the rockers (inner and outer) with air and because that media crap is so tough to get out, I decided to cut a couple flaps on either end and to my dismay, I found some (alot) of rust around the drivers side torsion tube. There are 3 layers of metal welded around it... 2 outer and one hidden inside. It was this hidden inside piece that was worst. Lucky I found it now though. Interestingly, the pass. side of this car is basically rust free. Weird! Here are some pics after the rusted metal was removed and repairs under way. It looks somewhat sloppy but I had to fab it together by hand. I also had to cut some of the rear seat out to access the mess I must say it's coming together nicely and looks factory. I'll post some photos when it's completed. Notice the sway bar mount had to be removed as well. Yikes! These pictures show the inner most sheet metal being welded in. ![]() ![]() ![]()
