Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Picklex Users- Is this normal?
Just finished, I think, patching, welding, grinding, re-welding, etc the front valence and gave it a spray and brush on of Picklex to try to protect it until I get around to putting primer on. Now it's got the orange haze that looks all the world like surface rust. I even ran the scrubby over it an re-applied the Picklex, but got a similiar result. Is this normal?
There really wasn't any rust on this part to start with or following the repairs, it's mostly new metal especially in the shot of the corner from inside the trunk. Just looking for other opinions before I go further.
Tim
Tim
'69 911e (work in progress)
‘20 Honda Ridegeline
'22 Subaru BRZ
Restoring Jewel's 911e
Old 01-16-2012, 04:14 PM
hemeoncdoc
I have the same problem. I believe it is rust. Not sure if Picklex 20 went bad or what. I have not yet contactebdthe company but intend to.
Too many hobbies, too little time...
Old 01-22-2012, 07:33 PM
Bird. It's the word...
Fishcop's Avatar
You may find it's actually zinc phosphate reacting to moisture - not actually rust. Just scuff it all down with a red scuff pad and epoxy or etch prime when ready.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-22-2012, 10:38 PM
Thanks, I'll give that a shot. I did give it another light squirt with the spray bottle and brushed it on again and it didn't seem to come back orange. Maybe I just didn't get enough on to start with.
Tim
'22 Subaru BRZ
Old 01-23-2012, 07:41 PM
I have never used picklex. I think John is correct. I have used Eastwood Metal Etch and POR15 Medal Ready which are similar products and they did the same thing.
Old 01-24-2012, 04:56 AM
Fishcop's Avatar
Here's a shot from my car a day after application whilst I was working my way to clean metal. I scuffed it all up prior to epoxy...
John Forcier
Old 01-24-2012, 03:23 PM
300hp 1800lbs is the goal
pksystems's Avatar
If I recall correctly, you are supposed to dry the surface after applying picklex..... spray it on, scrub it, let it sit a few minutes, and wipe it dry.
The carrier for the phosphoric acid is water I believe, so it probably is a light surface rust...
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-31-2012, 08:21 AM
Classic's Avatar
Looks like you let it dry on the surface, hence the light coating reacting with the atmosphere.
I tend to only do a small area at a time, and wipe down with a clean rag, and get a grey look to the panel, and I've had some panels sitting for over a year.
As John said just give it a scuff down before paint and you're good to go.
Classic 1969 911T
Old 01-31-2012, 01:10 PM
Exotic Vehicles are here
1-ev.com's Avatar
On Picklex20 website they said this is OK Picklex20 Manufacturer Home Page Metal surface preparation, steel pre-treatment.
My 2 c.
-Y.
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 02-01-2012, 09:12 AM
Brownish color for Picklex 20
Sometimes a brownish color is noticed after drying of Picklex 20 coating. It is a part of the coating and not rust. The rust color is orange. Also, any whitish powdery residue on the surface happens when the excess Picklex 20 is not wiped off completely from the metal surface. There is no zinc phosphate in Picklex 20. Picklex 20 is a water based product.
Any question, call International Chemical products, Inc. (manufacturer of Picklex 20) at 256-650-0088. Web site: www.picklex20.com
Last edited by saswata; 03-02-2012 at 04:57 AM.. Reason: To put the web site address
Old 03-02-2012, 04:55 AM
1-ev.com's Avatar
Also DO NOT SCRUB after Piclex appled
+ '68 911
Old 02-21-2015, 08:35 AM
hemeoncdoc
I have had the same thing with Picklex. Definitely not rust! Areas that turned that color remaining stablem without developing rust. I had an area unprotected with Picklex, that area did rust but a darker red-brown typical rust color. The Pickles areas turn more of an orange color. Not sure about the chemistry there...
Old 04-25-2015, 05:39 PM
