Eva
911SauCy's Avatar
930/10 versus 930/04 Ignition Timing Specs
Before I was a 930/10 owner, I had the original US Cali delivered '78 3.0 930/04 in my car.
IIRC, igintion timing spec on that motor is 5 Deg BTDC at idle and 25-26 Deg Advanced @ 6k RPM (timed it a couple times but about 3 years ago)
Now that I'll be bolting the '83 930/10 motor in my car (ideally) this weekend...is the ignition timing spec the same as above?
SauCe
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-28-2018, 04:18 AM
Bill Verburg's Avatar
SauCe
For the '81 -83 SC's they seem to have pulled back max timing and the method
spec fr these is max not above 25 BTD checked at 4000rpm, earlier SC ran up to 31BTDC
the RoW don't mention an idle spec, US does 5BTDC
all w/ vacuum disconnected
Bill Verburg
Old 06-28-2018, 05:12 AM
Eva
911SauCy's Avatar
Really, don’t check the advance w vac connected?
Old 06-28-2018, 05:27 AM
That's what the book says
Bill Verburg
Old 06-28-2018, 06:02 AM
Eva
911SauCy's Avatar
Roger that!
It's why I asked
Thank you
Old 06-28-2018, 09:26 AM
