Alex599's Avatar
Replacing clutch helper spring. Missing part in PET?
Hi fellow Pelicans,
I’m in the process of changing a broken clutch helper spring and am having a hard time finding a rubber seal on PET. If you look at my picture, you can clearly see a seal on the charge arm but in PET it’s nowhere to be found. Worse case scenario I can reuse the old one but I’d like to replace it if possible. Any thoughts?
1984 Carrera 3.2 Cabriolet
Old 07-11-2018, 09:19 PM
ROW '78 911 Targa
timmy2's Avatar
3 sealing rings listed as required for an SC, only 2 shown in drawing a possible clue?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-11-2018, 09:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Two goes into Bell housing at fork & shaft and one as pictured, there is no dust guard between Omega and Clutch Arm.
'85 Carrera Targa
PCA/POC
Old 07-11-2018, 10:03 PM
proporsche's Avatar
there are always 3 seals and the seal must be on the little finger to prevent dirt going into the vertical shaft and keep the lube inside ....
If you look on your PET it is written it takes "3"
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-12-2018, 12:26 AM
Alex599's Avatar
Ivan
Ok, so I guess they only appear to be of different size due to them being worn? The one between the clutch release lever and et bellarm seems way larger than the one sitting on the change lever. Where does the third one go?
Old 07-12-2018, 06:42 AM
theiceman's Avatar
i put one of item (4) above the helper arm , and one below the helper arm , and called it a day.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-12-2018, 07:15 AM
proporsche's Avatar
one goes on bottom of the fork and the next on top of the clutch arm and the 3rd on top of the finger..
Ivan
Old 07-12-2018, 11:34 AM
zje zje is offline
Same. I used 915-301-139-00. Interestingly enough there was no old seal above the helper arm when I did this.
83SC Targa US
2001 VW GTI VR6
Old 07-12-2018, 06:49 PM
theiceman's Avatar
I didn't think there was either on mine, but when I got in there I found some hard remnants, long ago vulcanized through heat and the elements.
Old 07-13-2018, 07:11 AM
