Any jacking pitfalls?
Okay, so first Porsche here and going to do my first oil change on it. Ordered my oil, and filter and crushrings,
So far everything on this car is just a bit different than any other car I have had. I am looking and reading about the oil change and trying to read between some of the different opinions. Wondering on the jacking of the car for an oil change, looking like generally you lift it and get her up and level after a good warm up. Are there any pointer when jacking these cars to make sure I don't create expensive regrets? |
Also, I was thinking about a lift, saw the QJ here on PP and thought that was a neat solution. Anyone here invest in a lift for Porsche care duties?
You don't need to jack it to change the oil. Be prepared for an onslaught of oil when you drain the tank. I warned you. Don't over tighten the filter or the drain plugs.
Oh and make sure your container can take a large quantity of oil quickly. Be prepared.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end Last edited by carreradpt; 07-19-2018 at 07:05 AM.. |
Brew Master
I have never jacked my car up to change the oil. Mine is lowered to about Euro spec. maybe a bit lower and I can still get a pan under the engine plug and I use a cut 5 gallon bucket for the main tank. As for jacking the car up, I spent the money for the jack pad. Money well spent
https://www.pelicanparts.com/More_Info/SIC80400000.htm?pn=SIC-804-000-00&gclid=CjwKCAjwyrvaBRACEiwAcyuzREZhp9gNAiPwqGpgJy05 JSnvnvsLu8WbuWeC7rQlIHPZrti-3HOvyBoCzSAQAvD_BwE Last edited by cabmandone; 07-18-2018 at 07:03 AM.. |
Brew Master
^^^^ That right there! First time I changed my oil I used my normal pan that only has about a 3/4 opening in the top. Suffice it to say that didn't go well.
Like this?
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
Registered Minimalist
Go slow. Be 100% Safe.
Many pitfalls. Use the torsion bars in the back. Use a rag on the jack to protect the bar. Use the jack pad Pelican sells ( the extension piece that goes in your side jack point in the rocker panel) I like to have a spare wheel under the middle of the car as an extra safety precaution. Once you have it jacked up, put one of the wheels under some low point. Better to crush the car / wheel than your body. Get one of those 5 gallon home depot orange buckets. Just drain right into that. A plastic oil pan with a small hole will get overwhelmed and will overflow onto your garage floor. There are many lift threads on here.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Yup I have the jackpad, PO included it with the car for me. I kinda like the idea of not having to lift the car for an oil change. Sound likes its a little tougher to get to things but still doable.
Brew Master
It's really not bad getting at things or at least I don't think it is. Compared to changing oil in my daughter's Ford Fusion I think the Porsche is easier (more expensive... but easier)
Make yourself some ramps with a couple 4x4s and a 2x8 on top. I have a set of 4 of these. I work on alot of cars and more than half the time dont need to jack them up. Its alot faster and safer for you and the car. They are still a bit low for working under the porsche but it even helps to use them when jacking the car up because you arnt lifting it at an angle or as high before getting the stands under it.
82 SC , 72 914 |
Jacksonville, Fl
All of this...really it a lot of oil. And the Jack pad does make life easier.
Alex Jacksonville, Fl '88 Carrera, Guards Red |
My solution to the oil collection question. I do NOT jack the car up and it has been lowered.
Here is a post on where to jack and support your car: Quote:
The absolute main advise I can give you is "Don't Over Fill It". I, like many others poured new oil in until it reached the full mark on the dipstick like on any other car. After several days of trying to figure out why the excessive smoke on start-up and doing some research there was the very messy job of trying to drain out a couple of quarts of that nice new oil.......usually all over the floor. From my experience, only pouring in about 8 quarts to start with, run the engine, then add until you hit the quart low line on the dipstick. This level, for me, works great. The oil tank holds lots of oil so you aren't going to run out.
It's tight under there but can be done without lifting. The rear of my car sits on roll around jacks all the time so I can push it against the wall out of the way most of the time. These can also give you a few inches for oil changes or clean-up. Good luck!
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
I agree you don’t need to jack for an oil change.
As for lifts, do a search and you will find plenty of opinions. Four post lifts, scissor lifts, Max Jacks, Quick Jacks. I have a Quick Jack because I have very limited lift height in my garage and I like being able to easily move it and use it in the driveway. Mark
1979 911SC Targa |
If using a jack pad, keep an eye on it while lifting as they can slip out of the slot. Using a floor jack placed perpendicular to car seems to make it worse, especially if floor is not smooth (like brushed concrete). Having the jack placed more parallel to car helps combat this. Love the wood ramps. I see that project in my future!
Spiderman
Like many others say, no jacking required for an oil change but getting the back wheels up a little on
some wood gives some welcome room to loosen the drain plugs and have the pan in place. A deep pan for the oil tank may contain the splash but it comes out fast.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Who makes this container you use? Thanks |
I bought one very similar to Harry's from a PepBoys, albeit it is black and red, not green and white.
Edit: Found it online at AutoZone. One thing I do remember now it I drilled out the drain port on the pan because it was a series of small holes. I used a stepped drill bit and made it one large hole. Works perfectly. https://www.autozone.com/shop-and-garage-tools/oil-drain-pan/flotool-16-qt-drain-container/700706_0_0?cmpid=PS:3:3:1&s_kwcid=AL!5142!3!193245103672!!!g!296308263339!&ef_id=WgIZxAAAAFqE-nxO:20180719221459:s
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 Last edited by '76 911S 3.0; 07-19-2018 at 03:16 PM.. |
You can use one of the large oil containers from wal mart- just make sure you use a hole saw to make the hole larger. You need as much oil to flow into the container as possible.
No need to get fancy... just get a plastic tub for dish washing. I put in 10.5 quarts when I change the oil and filter. May add another half quart after warmup to bring it to a mark halfway between the add/filled lines.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
