SEVENT9
'79 SC - Thoughts on AC delete
I'm considering my AC options. I got my first 911 last week. A.C. is installed but not connected (no relay or fuse and no belt). I have no previous experience with 911s!
I have read a ton of threads here about how to delete, everyone's opinion on whether to or not seems divided. So my question is this: Should I throw in a new relay and fuse and put a belt in and see what happens. I assume I'd then need to recharge etc. and potentially troubleshoot a world of problems from a non-operational AC. Or should I save myself a world of pain about at least 40lbs of dead weight and pull it completely and if I did would it have any resell value? Thoughts?!
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html |
I bought my first 911 almost a year ago, an 80 SC Targa. AC installed but not working. From the research I have done I don’t believe it is worth the trouble to refresh it given the apparent fact that these systems never worked that well in the beginning. I pulled my compressor and condenser a couple of weeks ago, not so much to save weight but more to make it easier to work in the engine bay.
My plan is to save up for a Classic Retrofit Electrocooler while watching their early adopters to see how they do and how the system does. |
SEVENT9
Yes I been looking at these with great interest. It seems like a far better solution and I have not seen any rave reviews about the AC in these 911's. They seem reputably bad. I'm leaning strongly towards it's removal I think but, as a newbie in this world, I am understandably hesitant.
As to removing the system (vs. leaving it as-is and inoperative) -- Think it depends on your intended use and how sensitive you are to extra weight. The counterpoint to removing all of the AC components is that it makes your car less original and potentially less salable/valuable to certain buyers. I haven't bothered charging or using the AC on my daily driver/not tracked targa since I moved to colorado in 1999. A few years ago I removed the belt to the compressor but haven't done anything further to remove my ac unit. While I realize that I'm carrying around 40 xtra pounds of junk, I honestly can only feel an incremental difference in performance when carrying a passenger that adds 3-4x that weight to my car and therefore question whether I'd realize any perceptible change after stripping out all of the AC-related "stuff" -- that said, i continue to consider removing the compressor and condensor (low hanging fruit where I'd most like to see weight reduction) one day -- just LOW on my list of priorities for a street daily driver. Last edited by darrin; 05-23-2018 at 11:50 AM.. |
Still here
Fleabit peanut monkey
Toronto and Portland. The original AC system is almost adequate that far north if you put the 47 hours into the system to bring it back to scratch.
![]() By that I mean to kill all the snakes that degrade the system. E.g., fuzz buildup on the bottom of the evaporator. Way easier said than done. That's one of about 20 things.
1981 911SC Targa Last edited by Bob Kontak; 05-23-2018 at 11:58 AM.. |
SEVENT9
SEVENT9
SEVENT9
It will be work to not eff stuff up if removing. Worth the effort. I am guessing ten hours for an enthusiastic DIY guy. Bag stuff up. Put it in a big box or two in the attic and save it for the next owner. You never really own a Porsche, you just feed it for a while.
It's more than 40 lbs. But I don't know how much more. I remember reading that it's 105lbs for everything. That was me reading something one guy posted 20 years ago. If you are going to remove it, get it all out save wiring. If you have it in a box and someone likes your car and you have the kit, they wont freak out.
1981 911SC Targa |
Still here
There's a dude Raw something in Texass hell or someplace like that who thinks differently. He knows the AC stuff. Last edited by pmax; 05-23-2018 at 12:58 PM.. |
Ass-engine Nazi slot car -- PJ O'Rourke |
Spent $3K to repair and convert my working A/C to R134a and it does ok in NJ. It has been a lifesaver on long trips to keep humidity down and cabin comfortable, but marginal once temps get over 85-90 degrees F. 12 years later I am glad I have it.
That said, it gets used just a few times a year and costs a lot to convert (was working when I converted), not to mention needs yearly charge in spring which is an annual 1-hour project that's not hard, but not particularly fun. If I bought another SC I would likely toss the A/C if it looked abandoned as it would surely be a lot of $, effort and possibly aggravation for marginal benefit, however, as you just got the car, I say do nothing. Remove it later if you don't miss it. Let the car and how you enjoy it reveal itself for awhile.
Scott 1981 911SC Targa - Platinum Metallic Last edited by schoward; 05-23-2018 at 06:20 PM.. |
Banned but not out, yet..
In Toronto you really don’t need it.
Restoring or converting it would cost a small fortune and would net you mediocre performance unless you pop for 6 large and buy a totally reengineered system from RennAire Porsche 911 Air Conditioning Products which works great. If I were you, I would pull out the dead weight, exactly where you don’t want it, in the back end. Then put it all in a box and save it if you sell the car you can say it includes original AC components not installed. I took mine out and never regretted it, but I live near Seattle.
An air cooled refrigerator. ‘Mein Teil’ |
Remove it. And the hoses. It's at least 50lbs of garbage. All A/C systems were installed in north america by dealers, they were not original to the cars.
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
It will cost many thousands and end up being "ok" at best. I'd spend the money on retrofitting opening rear windows.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Perpetual Reassembler
I removed the AC in my 83 SC for several reasons:
1. It had 200K miles when I got it and has been heavily modified. It will never be a concourse car ever. 2. The compressor and condensor(?) under the decklid were gone when I got the car, and the AC hoses were open, exposing all the internals to the elements. 3. During removal, as I suspected, most of the components were already trash. The little heat exchanger attached to the blower in the smugglers box was green with corrosion when I pulled it out. 4. Since my car will be modified for the rest of its life, I am totally ok with removing the original system with entrails scattered all over the car and eventually replace it with a modern electric system that fits under the hood. I guess it depends on your car's condition and what your long term plans are for it.
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
SEVENT9
Thanks everyone for all your advice! Yes, this car will no doubt end up being modified as well. 120k on it and I ran it over to my local mechanic to see if he thought there was any refrigerant left, he couldn't find a few of the pieces he was looking for so it looks like a partial removal has been done already even though the compressor and condensers are still in place. I'll be disconnecting the condenser later today and pulling the whole system when I have some time. I'll leave the removal of the left over smog pipes for when I switch to SSI's and upgrade the exhaust system likely this winter.
SEVENT9
