84911 will not start
Just back from a two hour drive and the car will not turnover. No turning over just a buzz noise from the engine compartment. Any suggestions?
1988 Carrera
Check batt connections
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Member 911 Anonymous
+1 check connections and voltage. You need to be over 12.5 volts
Your starter may be heat soaked. Get under her safely and tap the solenoid attached to the starter. To confirm starter issue, push start her. Won't take much of a push, heck, I did it in reverse when my starter went out when facing in, in a parking spot. Break a Leg, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Cheers, Joe |
Thread Tools | |
Rate This Thread | |
