damage on my case... is this an issue?
I noticed that something had fallen into my recently machined case half and damaged part of the mating area and edge. (apparently someone knocked something off a shelf and it fell)
Does this need to be repaired? Is this acceptable still?
Please look at pictures and comment. Thanks!!!!
1987 Porsche 911 Carrera Coupe
Old 09-16-2018, 07:00 AM
Steve F's Avatar
Thumbs up
I would just take a flat stone and wrap it with some 600 grit sandpaper and just slowly run over the area until there is no burr left then stop, you will be fine
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 09-16-2018, 08:27 AM
proporsche's Avatar
A Steve said not a big deal if it is smooth and no lip do not worry too much-it is more to the inside of the case......but, i would send the picture to the machine shop who did the damage and was not careful with your engine case..
Ivan
1985 911 with original 501 761 miles...807 506 km
Old 09-16-2018, 08:59 AM
its not a burr... but a dent. case was on the ground and something got pushed off counter top and fell onto it and caused the dent.
There are 2 dents where the mating occurs as well as a dent on the outer edge.
Old 09-16-2018, 09:54 AM
Ivan
it was my own fault... a hose nozzle fell off and landed on the case.
the edge is flat, just a couple of dimples/dents and the outer edge is slightly hit.
Old 09-16-2018, 09:55 AM
By the picture it looks to me like that was preexisting when the machine work was done. I don't se any distortion to the machining Mark's, and you say there is no high metal, which would confirm this. If that had happened after machining, that metal would have been displaced causing the adjacent metal to be high. If the mating surfaces are smooth you are good.
Old 09-16-2018, 10:04 AM
proporsche's Avatar
trakrat..i c, in any case do not worry too much...............
Ivan
Old 09-16-2018, 10:12 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, Don't worry about it. Thanks goodness you missed the Journals, then we would have a another story here. Just be mindful and keep cats away, darn hair can kill your engine. :-)
'85 Carrera Targa
PCA/POC
Old 09-16-2018, 10:30 AM
Good to know.
I did notice a small 'knick' on the edge of one of the journals. The only reason I noticed was from the light bouncing off it and made it shine more than the journal itself. My fingernail catches on it when I run it along the edge.
I don't think it should be an issue as it is really small and I should be able to file it down on the outside edge of the journal to smooth it out slightly.
Old 09-17-2018, 05:42 AM
Apparently it was a solid, straight hit... I found my hose nozzle has a metal grip that matches the indention that was made.
Old 09-17-2018, 05:44 AM
Much ado about nothing,the case sealant will fill that void very nicely.
Stop worrying.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-17-2018, 06:15 AM
DRACO A5OG's Avatar
Ouch, okay if there is a high spot, you must take it out as it will cock eye the bearing seat and potentially bind the shaft or accelerate the bearing wear or worse affect the hole rod assembly up to the pistons/cylinders. Just be very mindful how much you take off, this must not be a rush job.
BTW, if you use orange 574 sealant on the original pic of the dent, sealant will dissolve away, again do not worry about, the two little triangle dimples will fill in and stay solid because the other case half will seal it with 574.
Originally Posted by Trakrat View Post
Good to know.
'85 Carrera Targa
PCA/POC
Old 09-17-2018, 07:14 AM
I would smooth out the half moon looking defect. Lots of stress risers there.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 09-17-2018, 11:43 AM
Thanks Snitzler… I'll double check to make sure the top is smooth and flat.
Old 09-17-2018, 11:50 AM
