PKE Push Button Start Install
Has anyone installed a PKE Push Button start on an older 911, specifically 78? Thought I had found a post where someone had mapped out the electrical connections of the ignition switch but can't seem to find that anymore,
thanks
1978 911SC 3.0 "Guards"
Old 09-21-2018, 02:53 PM
safe's Avatar
Why on earth would you want that, is your ignition switch broken?
Magnus
Old 09-22-2018, 10:39 AM
at the risk of answering a rhetorical question,,, yes my ignition switch is broken as they are prone to doing, and not just the electrical part, the mechanical pawl broke off - so given the enhanced security, ease of use and ample supply/selection at reasonable prices I had assumed this was something that someone else had already thought of and tried out,,
Old 09-22-2018, 03:30 PM
ROW '78 911 Targa
timmy2's Avatar
Run a red 12 gauge wire for Switched power from the fuse panel (you Pick) to the button. Then run a 12 gauge yellow to the area with a yellow wire with a single pole connector coming off the back of the ignition switch 6 pin thru dash connector. (In the trunk) Replace the one coming out of the 6 pin connector. (Connects to the one going to the through body harness to the starter solenoid)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-22-2018, 04:18 PM
thanks - I was wondering if I could simply plug wires with bullet connectors into the female connection that normally plugs onto the electrical portion of the ignition switch,
the new switch has:
Red + power 12V+
Black - Ground
Brown + On2
Blue + Acc
Yellow + Start
While + On1
Green = either connect to brake or clutch switch
Old 09-22-2018, 05:02 PM
lespaul's Avatar
I want to do exactly this in my '78 SC. Did you end up doing it and, if so, did you have any further details/pics of what you did?
tX
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 04-13-2019, 08:56 PM
I actually ended up purchasing a new porsche ignition switch and steering lock assembly, it wasn't cheap but easy to install, works great and I am trying to be very selective about what I change from stock on the car and the push button idea just seemed a little too far for me, only issue is I have one key for doors and one for ignition now but that is fine,
Old 09-26-2019, 06:10 AM
