PKE Push Button Start Install
Has anyone installed a PKE Push Button start on an older 911, specifically 78? Thought I had found a post where someone had mapped out the electrical connections of the ignition switch but can't seem to find that anymore,
thanks
1978 911SC 3.0 "Guards" |
Why on earth would you want that, is your ignition switch broken?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
at the risk of answering a rhetorical question,,, yes my ignition switch is broken as they are prone to doing, and not just the electrical part, the mechanical pawl broke off - so given the enhanced security, ease of use and ample supply/selection at reasonable prices I had assumed this was something that someone else had already thought of and tried out,,
ROW '78 911 Targa
Run a red 12 gauge wire for Switched power from the fuse panel (you Pick) to the button. Then run a 12 gauge yellow to the area with a yellow wire with a single pole connector coming off the back of the ignition switch 6 pin thru dash connector. (In the trunk) Replace the one coming out of the 6 pin connector. (Connects to the one going to the through body harness to the starter solenoid)
thanks - I was wondering if I could simply plug wires with bullet connectors into the female connection that normally plugs onto the electrical portion of the ignition switch,
the new switch has: Red + power 12V+ Black - Ground Brown + On2 Blue + Acc Yellow + Start While + On1 Green = either connect to brake or clutch switch
I want to do exactly this in my '78 SC. Did you end up doing it and, if so, did you have any further details/pics of what you did?
tX
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
I actually ended up purchasing a new porsche ignition switch and steering lock assembly, it wasn't cheap but easy to install, works great and I am trying to be very selective about what I change from stock on the car and the push button idea just seemed a little too far for me, only issue is I have one key for doors and one for ignition now but that is fine,
