Moving the fuel pump forward near the gas tank
One of the quirks of the 1973.5T/CIS model is that the fuel pump in mounted in the rear wheel well and despite the claim that the pump has a check valve, every time you restart the car you have to draw the fuel back quite a ways to get it started. Listening to the engine when starting (without hand throttle and car warmed up) you can hear the cylinders slowly charge and eventually start. It can be a slow and frustrating process.
I was advised that the way to remedy this is to mount the fuel pump forward behind the tank to push the fuel rather then pull the fuel for quicker starts. Very little fuel drains back into the tank with this new configuration.
It would not appear to be difficult to perform, aside from fabricating a mount in the area of the pedal cluster or master brake cylinder. A new fuel hose would have to added and the fuse link identified. The fuel pump on the 1973.5T does NOT have a relay associated with the pump. I believe power is drawn from fuse 7 or 9.
I have to ask, if anyone has anyone performed this operation and just how successful it has been.
Bob
73.5T
Old 10-29-2018, 07:21 AM
Bob
73.5T
Yes, I had that change made on my 73.5T. Actually, it was done by a PO and I modified it a bit when a new pump was needed. Since there was no bracket on the front cross bar, one was fabricated along with some padding for vibration dampening, and new hoses to connect it all together. Nothing too difficult. I no longer have the car so I cannot give more detail except to say it was an improvement and was easier on the pump.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-29-2018, 07:54 AM
Would it be possible to fit it where it is mounted on slightly later cars such as SCs ie on the front cross member? You could then use existing parts.
Ian
Old 10-29-2018, 08:01 AM
Not sure where it would be mounted or shielded. but I suspect under the removable panel that protects the pedal cluster, brake master cylinder, etc. near the tank. This model (1975.5T) was the only one with this configuration for the CIS system. It was changed on the 1974 model going forward. Further, no relay is present for the fuel pump on this model. The 1973.5T is an interesting car (no fuel pump relay, no thermotime switch, hand throttle, no adjust WUR, etc).
Old 10-29-2018, 10:00 AM
So, right now, you have no circuit to shut off the fuel pump if you're in an accident and incapacitated?
Old 10-29-2018, 09:47 PM
joefrantz's Avatar
Here are some past discussions on this topic:
Relocating fuel pump up front with steel cross member.
Joe Frantz
73 911 T
Old 10-29-2018, 10:07 PM
Registered Minimalist
75 911s's Avatar
My 75 has this exact same setup. So at least 3 Model Years. Starting in 76 they are mounted in the front.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 10-30-2018, 04:35 AM
BoxsterGT's Avatar
Porsche Crest
I make up a front pump mount for the early cars.......
This also has a Dansk Tank that I have supplied a Pre-Filter for to protect the new fuel pump.
For info, please email me. Len dot Cummings at verizon dot net
Old 11-02-2018, 01:05 PM
fred cook's Avatar
Easiest/possibly best way is to replicate the design used on the SC cars. As mentioned earlier, you can use all original parts. All you would have to do is drill a couple of holes in the rear side of the crossmember. And, it is shielded there by the front cover.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 11-03-2018, 06:04 AM
Harpo's Avatar
How do you power the fuel pump now that it is located up front? I pulled my tank today and plan on getting new fuel lines from Len after the holidays
Old 12-14-2018, 03:40 PM
BoxsterGT's Avatar
Porsche Crest
Early 911's have a tubular crossmember, so the SC mount will not work.
I am using rubber lined loop clamps and (2) metal angle brackets. The lower is supported by the crossmember and the upper by the steering rack.
It's a little offset to one side but the hoses still seem to fit nicely. The photo above gives you an idea of how it mounts, but I will post another as soon as I put one more together and paint it.
Len.Cummings at verizon.net
Old 06-21-2019, 05:37 AM
Moving the pump to the front is a good idea.
My old 914 had the fuel pump in the engine compartment. The gasoline vapor point was changed, and I would get vapor lock while cruising down the highway at 55 MPH in the bad ol days of 55 MPH limit.
I moved it to the front and never had that issue again.
Old 06-21-2019, 05:41 AM
BoxsterGT's Avatar
Porsche Crest
Rec'd another inquiry, so here it is before paint......
Got to keep these wonderful cars on the road for generations to come.
Len
Old 06-21-2019, 09:28 AM
