Maxilite Fuchs quality?
Has anyone ever used the brand maxilite Fuchs wheels?
I have some and they are nice. Obviously not as strong and light as real Fuchs since they are cast and not forged, but decent wheels. The finish is good on them and they have a lot of sizes. I think the finish is nicer than the Rota and Euromeister replica wheels I've had.
Thanks for the response. What size are you running Cory?
Guest
Posts: n/a
I like mine a lot. I have 6&7 x 16s on my car. Well finished.
Has anyone run 9s in the rear on a sc?
Schleprock
Yes, many many many people have run 9s in the rear without any modifications.
The wheel offset has to be correct and the original Fuchs 16x9 has an offset of +15mm (slightly more than 9/16"). The Maxilite 15x9 and 16x9 both have the correct offset of +15mm
Kevin L '86 Carrera "Larry" |
As Keven pointed out 9ET15 2/ 245 tire is a great fit for an SC/Carrera. It's shy of a max rear fitment w/ ~.25" clearance at the lip, more if extra camber is also used.
Cars and Cappuccino
TUV approved. Better than most, if not all the other fake Fuchs manufacturers. I have a set of 9's and 11's I am planning to run on my widebody build.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
I think 8s are a better choice than 9s in the rear only because of limited 245 tire availability. 8s can run 225s and 245s comfortably. 9s can only run 245s. So if 245s are ever unobtainium, you can always go back to 225s
Tru6 Restoration & Design |
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
Marisol that pic your running 9s in the back?
Yes sir! re-11 245/45/16
lowered to a smidge under euro height
Your car looks great Paul! Perfect stance.
Does anyone know if 245/50/16s will fit in the rear? Just did a quick search for 225 and 245 with 45 and there’s not really much tire options. There’s a lot more with 50
Second that your looks great love the stance Paul!
They are strong enough for track work, only thing I don’t like is the machined face on the lips (similar to the euromeisters). Might get mine polished or painted
Flat sixx, Thanks for the love!
