| Registered |
			This is how I do it - works well for me... and cinder blocks are cheap! https://www.youtube.com/watch?v=SxAcLwzAJ3w
				__________________ Michel 1970 911T | ||
|  01-09-2019, 03:28 AM |
| Registered Join Date: Jun 2009 Location: New England
			911T70, That was a very impressive film! Worth several thousand words! Thanks so much.
|  01-09-2019, 03:37 AM |
| Registered |
			When I was getting ready to rebuild my engine, I kept on checking the classifieds for Porsche tools. Eventually, I found an ad where an engine had been rebuilt and the builder was getting rid of all the Porsche specific engine tools including the 5 leg yoke, cam tools, etc. I was able to buy the whole set for the price of the yoke! It never hurts to keep your eyes open for deals!
				__________________ FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning | ||
|  01-09-2019, 04:17 AM |
| Registered Join Date: Dec 2014
			Keep in mind the harbour freight cherry picker(hoist) has legs that are not wide enough to straddle the 911 motor. I cut mine up and built a rotisserie, found a $99 coupon and bought another for the front.
|  01-09-2019, 05:04 AM |
| Targa_PB_78_SC |
			yes 911T70! very great and informative video on UTUBE, maybe I will drop my engine some day!
|  01-10-2019, 01:49 PM |
| Registered | Quote:
 Drop your engine if you get the opportunity. It's intimidating at first but not that hard. I'm very happy I learned to drop mine - my car wouldn't be running as well as it is if I hadn't; makes routine maintenance/repair so much easier and it's a bonding experience with these amazing machines! Here it is going back in: https://www.youtube.com/watch?v=eAZm6SyTS1U
				__________________ Michel 1970 911T Last edited by 911T70; 01-11-2019 at 09:57 AM.. | ||
|  01-11-2019, 04:01 AM |
| I am my 911's PO |
				transferring engine to stand
			Like many of you, I work solo and need a safe, dependable way to transfer the motor to/from the engine stand. After I figured out that supporting the motor with stacks of scrap lumber did not fit those criteria, I started using a chain hoist. Initially I hung it from the ceiling joists, but needed a way to move the engine to the shop side of the garage (there's a step between shop and parking areas) so I made this trolley:   The trolley (part that rolls) and supports are from McMaster. The Unistrut is from the local home improvement store. Trolley is rated for 600 lbs. Here's transferring between the engine stand and hydraulic lift table. Note the step: the trolley lets me move the engine past the step and put the engine stand on the upper level:
				__________________ 1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive | ||
|  01-11-2019, 05:39 AM |
			DPMulvan,  You raise a good point concerning the width of the cherry-picker legs! I'm thinking that the legs would need to be wide enough to slip around the ATV lift I'm using to drop the engine. The engine is wider than the lift, but I'll have to do some measuring. On the other hand, if you can secure the cherry-picker from sliding, wouldn't the engine just swing into place as it's lifted? Or slide into place using some plywood over the cherry-pickers legs? Just pondering... Thanks again! Robert | ||
|  01-11-2019, 06:20 AM |
| Registered User Join Date: Dec 2014
			There is more than one way to skin a cat.  I used my welding table on wheels to support the engine as I undid all the connections and lifted the car up using a four post lift. Exhaust removed. Completely disassembled the engine, then decided I liked working at the higher height of the table instead of the height of my engine stand, so I made a couple of wood stands in the shape of the crankcase in the upright position and 90 degrees rotated. Did all the work assembling on the two wood stands on the table. It was really handy to have a flat surface all around the engine. There was plenty of room to work, and very sturdy. If I did it again, I might make some slick aluminum stands to replace my wood ones, but I would still do it on the table. The only reason I could see to have the engine upside down is for the exhaust, and I did that in the car. | ||
|  01-11-2019, 07:05 AM |
| Northern Motorhead |
			I posted in an engine removal thread a few years ago where i lifted the rear of the car with an engine hoist using the engine support bolts and a home made sling with chains ... made a wooden dolly to drop the engine on and rolled it out from under the car. While searching i saw some pretty scary set ups whereas some really intrepid mechanics had their car jacked up on a pile of wooden blocks. There are many engine removal threads on the forum , you just need to find the right one !
				__________________ Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 | ||
|  01-11-2019, 07:49 AM |
| Registered |
			Piscator (is that fisherman as I recall all that wasted time learning Latin); The problem is that you have to stretch a cable from the cherry picker to the engine be case the legs won't fit under the engine. When you start jacking it just pulls the stands rear legs up. I am pondering a solution to this as I contemplate how to get my engine onto my new engine test stand!   | ||
|  01-11-2019, 11:44 AM |
			Strygaldwir, Piscator is the name of Sir Isaac Walton's sidekick in "The Complete Angler," but yes, also "fisherman" in Latin. I'm more familiar with the former than the latter! ;-) I see what you're saying about the cherry-picker's rear legs. I think my best bet is to hoist it on the laminated beam in my shop, it's plenty strong. When I went to Harbor Freight today, I could see the cherry-picker wasn't going to work. BTW: HB's having a three day sale. I got a $30 discount on the 1ton engine stand and 6ton jackstands for $37 ($7 off).!! Thanks for your post! Robert aka: piscator Last edited by piscator; 01-11-2019 at 11:59 AM.. | ||
|  01-11-2019, 11:55 AM |
| Registered Join Date: Feb 2000 Location: Dallas, TX
			I used a come-along the first time to get my engine onto my HF engine stand... I realized when I was done that a come-along works great going up (tightening), but not down, so I bought a chain hoist from HF. It's much more robust and less risky.
				__________________ Neil '73 911S targa | ||
|  01-12-2019, 08:27 AM |
			911T70, I'm copying your skid design for my engine drop; which is going to happen in about 15 minutes, as soon as I finish my pizza lunch! Everything is disconnected and all I have to do is 'lower away!' Your removal film has been a big help! Robert | ||
|  01-14-2019, 10:52 AM |
| Registered |
Good luck - let us know how it went!
|  01-15-2019, 02:50 AM |
| Registered |
				HF engine hoist.........
 Robert, The HF engine hoist legs opening could be overcome by a simple contraption. I have used this hoist for many years moving engines from engine stand to engine test stand much wider than the engine width. Like someone mentioned earlier, there are many ways to skin a cat. Or think outside the box. An ATV or hydraulic table is nice to have for your engine drop and could get away without an engine hoist. But having an engine hoist is an advantage and more efficient. What ever you decide to do, stay safe. Tony | ||
|  01-15-2019, 06:01 AM |
			Tony, What box????? There's a box?? :-) "Like someone mentioned earlier, there are many ways to skin a cat. Or think outside the box. Thanks Michel! Robert | ||
|  01-15-2019, 06:21 AM |
			Engine's out! Thanks to everyone for the help and support!!  | ||
|  01-15-2019, 01:53 PM |
| Registered |
Congratulations! A great feeling of accomplishment, isn't it!?
|  01-16-2019, 03:01 AM |
| Counterclockwise? |
			Nice!  It gets a lot easier each time you do it.
				__________________ Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs | ||
|  01-16-2019, 05:13 AM |
