The very foundation of Tru6 is surface prep. Honestly, that is 90% of what I do and specialize in. In this case, these were both mechanically and chemically polished to create the best possible surface for anodizing. The combination of the anodizing and prep, these are nicer than factory new.
Tru6 Restoration & Design |
Thank you Kevin! Those are ugly, ouch, I've never seen anything like that. I like to polish things so I do any chance I can. These pistons were all in good shape but I feel like they get "freshened" being in the tumbler (no abrasive media) for a bit. Great info on the piston steps, thanks. On orientation, I went by the original pieces, this link Tech Article: 930 Brakes and the manual. Reading the tech article, it says the step is to reduce heat transfer from the pad to the piston. Must be fun to be an engineer and think of things like that, and what you say, when desiging something.
Proper restore. Great photo's.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
This is some more very impressive work by Tru6. We don’t do much micro-restoration like this, but I can’t wait to see what my little Dino mirrors look like when Shaun is done having them plated! The calipers are amazing. - Matt
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA Last edited by Unobtanium-inc; 01-24-2019 at 07:28 PM.. |
fantastic work...
shaun whats the going rate to restore 930 calipers? i have a couple of set that may need to be redone |
a.k.a. G-man
Сидеть, ложь, Переворачиваться |
$900 per pair. More than PMB but I think worth the extra $101.
Absolutely spectacular work Shaun.....thank you for putting a price out there.
This will be number 1 on my wish list for a Santa Stocking Stuffer this year......nice to have a target. Approx turn around time? Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Thanks Scott! Figure 2-3 week turnaround time. That can easily go to 4 but a good estimate.
cycling has-been
Shaun, were did you buy your banjos?
Thanks Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Hey Bill, those came with the calipers. I tumbled them and then polished them.
cycling has-been
That's what I what I was afraid of.
Both my sets (on two cars) came without. You should see how the resulting brake lines (home-made) look. Bill K
sadly I sold it last year, hated to but needed funds for my 930 project. ![]() Quote:
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Schleprock
To reinforce the near-originality that you're getting with a restoration like Shaun's, here's a picture of a new 930 Brembo caliper. They don't make them the same as they used to. New ones come with white zinc fasteners and the anodizing is a shade of purple, not true black.
![]() Bill K, If you're making your own brake lines regularly, the hot setup i've found is to use the very nice cunifer tubing and a quality flaring tool. Belmetric has quality cohline tube nuts and the cunifer tubing. The cunifer is SO nice because its corrosion resistant and so agreeable to bending. I have the Eastwood turret style tool (unfortunately just one more example of someone copying and Chinese-ing the original brilliant tool, which I believe was made by Sykes Pickavant) and it makes excellent flares every time. The only issue i've found, and it's a minor one, is the resulting opening in the end of the line is too small. So I open up the hole with a small file after flaring (and clear out the debris with brake parts cleaner) to make it the same size as the tubing ID prior to flaring it. Here's a basic line I made to fit the 930 caliper to my strut. Looks just like the original you can buy from Porsche. However I also recognize that new OEM Porsche brake lines like these are very affordable. A new line like the one I made myself is currently like $13. ![]() But I also made some very long lines on my '86 Carrera in the front that would have been very expensive to buy. These were the lines that come from the tee near the steering rack and connect with the soft lines at the struts. Anyhow, I feel like the quality flaring tool pays for itself very quickly. Other split bar flaring tools are junk and are to be avoided. They are very inconsistent at making uniform flares and are basically dangerous in my mind when it comes to something important like brakes.
Kevin L '86 Carrera "Larry" |
nice work on the lines Kevin. There is a good reason to make your own over buying new. New have an extremely durable green coating on them. Fine for most cars but not for anything that will be shown or someone wants "off the assembly line" originality. I've stripped and replated a lot of these lines...have stripped and plate a lot of brand new Porsche parts for customers since the plating is either the wrong color or is just plain ugly. Fan straps are hideous from Porsche. Same with spring plate covers, etc.
Those are so much more beautiful than slathering red or yellow paint on them.
Kurt |
put new seals in mine, the inside ones.
had problems getting the pistons back in. contacted brembo about it. they sent me a part number for soaking the seals. did you actually pout grease on the pistons/seals
Sil-Glyde
So nice!
I feel bad for having shaved off some fins on my rear calipers....
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
