KTL KTL is offline
Schleprock
KTL's Avatar
Those that have seen a complete seal rebuild kit from Porsche/Brembo can attest to the kit including four things:
-Square cut pressure seal
-Dust scraper or boot
-Hard anodized piston
-Packet of grease
More recent kits i've seen have Kluber grease in them. Which is basically the same type of Sil-Glyde silicone grease that Shaun uses.
This grease helps get the pistons into the bores w/out hanging up on the pressure seals. The pressure seals are purposely shaped with a square cross section to grip the piston and retract it a tiny bit after you release the brake pedal. That tight fit & grip on the piston swipes off brake fluid and makes for difficult sliding of the piston within the seal. The grease is a MUCH better lubricant for inserting the pistons into the seals versus plain brake fluid.
I got some Centric brand seal kits (seals only, no piston, no grease) for a set of 964 calipers and they were a real bear to get the pistons inserted. I totally whiffed on using the grease I have on the shelf (mine is a tube of Dow Corning 111 that I had on bought for oil return tube o-rings years ago) and damaged the pressure seal pushing the piston in place.
Kevin L
'86 Carrera "Larry"
Old 01-30-2019, 09:15 AM
Wow, those look awesome, I too have a few sets, maybe we can do some horse trading.
Old 01-30-2019, 09:58 AM
Counterclockwise?
You have set the bar very high here!
Rod
1986 Carrera
2001 996TT
Old 01-31-2019, 01:54 PM
Shaun @ Tru6's Avatar
Another set of Turbo calipers done. These were the roughest set I've gotten so far. We ended up replacing every single piston. They turned out well for a very special car.
Tru6 Restoration & Design
Old 07-10-2019, 06:20 PM
Old 07-10-2019, 06:24 PM
a.k.a. G-man
Geronimo '74's Avatar
Originally Posted by 911tracker85 View Post
Geronimo, do you mean THIS 32C? I do not recall getting a member #.
sadly I sold it last year, hated to but needed funds for my 930 project.
Yes, that's the 32C I mean.
Had to ask for my number after I saw a few members post their's. I did not receive it initially.
Window of my office-container on the construction site.
Too bad 32C never gained enough momentum.
Old 07-11-2019, 02:29 AM
Slippery Slope Victim
NY65912's Avatar
Beautiful work Shaun!
Mike²
1985 M491
Old 07-11-2019, 03:56 AM
AutoBahned
RWebb's Avatar
I bet valve covers would look nice with that gray coating...
Old 07-11-2019, 10:33 AM
Eye candy for sure! Still hunting down a passenger side big fin so I can send mine out to you guy for this restoration! Keep up the great work!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 07-11-2019, 10:39 AM
Thank you Mike!
Thank you Jacob, I'll be here.
Old 07-11-2019, 06:50 PM
H-viken's Avatar
Shaun, how hard do you tighten the 4 M12 bolts that hold together the calipers?
Cheers!
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 01-05-2024, 11:30 PM
Johan, from memory, it's 60 Nm, but please confirm that with a factory manual.
Old 01-06-2024, 05:49 AM
Ballpark cost?
Old 01-06-2024, 07:45 AM
H-viken's Avatar
Thanks Shaun, will see if I can find a manual
Johan
911E Coupe -70
Old 01-06-2024, 09:05 AM
Originally Posted by MIAdragon View Post
Ballpark cost?
$1100 per pair Dragon
Johan
I will look on Monday Johan.
Make sure your pistons are in the right orientation before getting them together.
Old 01-06-2024, 11:03 AM
H-viken's Avatar
Thanks Shaun
Dragon, I can tell you that the parts alone, needed for a full refurbishment, aren’t cheap. Ask me how I know
911E Coupe -70
Old 01-06-2024, 12:27 PM
H-viken's Avatar
I ordered 00004302000 and got Castrols Mollub-Alloy Paste TA. Can this really be the right lube to mount the pistons in the bores? Seems pretty thick
Johan
911E Coupe -70
Old 03-12-2024, 05:44 AM
KTL KTL is offline
Schleprock
KTL's Avatar
No that paste is anti seize lubricant for fastener threads. It’s not for use in lubricating piston seals. Piston seals use a silicone paste
Kevin L
'86 Carrera "Larry"
Old 03-12-2024, 06:41 AM
Anything I can trade you to do 3 of my sets?
Old 03-12-2024, 12:23 PM
H-viken's Avatar
Thanks Kevin, that’s what I suspected. It doesn’t like right coming out of the tube
Johan
911E Coupe -70
Old 03-12-2024, 01:25 PM
