Don
Rear Seat Lock Help
No luck on Rennlist, hoping you guys can help. I called Pelican about this, they said they'd call back, but never did...
During previous ownership the rear seat lock knob came unscrewed. I can't figure how to get it back on. The spring loaded pin is still in there, so looking for directions on how to take the mechanism apart or ideas about how to get the little knob screwed back on.
Old 02-25-2019, 04:33 AM
Recreational User
porschenut's Avatar
It looks to me like the stud is sheared off, so the knob has nothing to screw on to. Unscrew the knob on the other seat and compare.
If you need to remove the seat back to work on it, unscrew the big slotted head bolt on the outside mounting point and you can pull the seat back. Careful not to strip the bolt though. On some cars they are a ***** to remove.
Old 02-25-2019, 07:46 AM
Don
Yes, maybe it is sheared off. I was thinking the spring just pulled it into the hole. Don't want to risk doin the same to the other one. Pelican can't find the part...never called me back.
Old 02-25-2019, 12:18 PM
911timesThree
rolfjahn's Avatar
I had to order the parts directly from *********** forward slash Porsche-parts
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod
1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod
2020 F87 M2 Comp 6Speed Carbahn 562/567
Gone: 1991 965 Black/Black Turbo
Gone: 2002 E46 M3 6Spd CSL style build
Old 02-25-2019, 05:45 PM
My 84 doesn't have this feature, so I cant verify anything, but...
Does the hole the pins lock into go all the way through? Maybe you can take a small screw driver from the opposite side and push the springloaded pin back out.
Old 02-25-2019, 08:17 PM
thisisgoodnews's Avatar
reviving this thread with my rear seat lock puzzle. the pins are present, but there seem to be no some sort bracket for them to go in. nothing has been modified or removed, no holes in the carpeting whatsoever. possibly came from the factory without locking rear seats? any known aftermarked or home DIY solutions for this?
Old 04-29-2019, 09:20 AM
If you look in the PET parts breakdown for the later cars with locking seatbacks (not sure of the years)you will find a small metal piece that can be welded on to provide the holes for the pins to lock into. Obviously someone put later style seatbacks into your earlier car.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 04-29-2019, 10:28 AM
wrxnofx's Avatar
You have to pull on the red knob so that the locking pin goes into the seat bracket. Then push the seatback upright and the pin should drop into the hole that is in the black metal bracket between the two seats.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-29-2019, 01:32 PM
wrxnofx's Avatar
Old 04-29-2019, 01:37 PM
The problem is his car doesn't have the bracket with the holes installed in
his earlier car. A larger later piece with the holes in it can be welded in place of the hinge piece in his car. This is what the later weld in piece looks like. I think the part# can be found in the PET for the later cars
'86-'89
edit: found the part# 911 501 041 02 FLOOR SEAT SUPPORT $23.25 Shows as NLA, but the $236 one is available YIKES!!
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&LastVisited_input=&description=91150104102
Old 04-29-2019, 02:14 PM
wrxnofx's Avatar
Looks like part number 91152256160.
Also looks like it might be NLA.
Old 04-29-2019, 02:35 PM
guys, thanks for help.
I will of course try the OEM path first, but your bracket seems to be different from the one uwanna has posted. is that a custom one?
Old 04-30-2019, 12:47 AM
wrxnofx's Avatar
No, this is standard on my '87.
You don't specify your year of car. It sounds like you have a '70's car that did not have the bracket with the holes for the pins. That's because cars from that era didn't use those knobs and pins to keep the seatbacks up. Rather, they had a strap on them that snapped onto the rear parcel shelf. So it seems like a PO took newer seatbacks that have the knobs and pins and put them in your car which was made for seatbacks that had the strap.
Old 04-30-2019, 08:49 AM
echecsqueen's Avatar
Early models solved this issue by putting snaps in. It is easy to add a female snap to the seat back and then a male one to the cross piece.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 04-30-2019, 05:20 PM
Snap placement '66
Sent from my BBB100-1 using Tapatalk
Old 05-01-2019, 01:19 AM
yeah, sorry for not providing sufficient information. my car is '86 and the orange interior is put from the '89 car. had a look at the original black backrests and you are correct - there are no red pins on them. this is what got me really confused, I didn't realize earlier models could have no way to secure the rear seat backrests in place.
thank you for your answers, my options are pretty clear now.
Old 05-03-2019, 12:54 AM
Smile Allen wrench
I had a similar problem on my '87 Carrera. The red plastic knob came off the metal shaft. In my case, it had just unscrewed and the red knob wasn't damaged. I was able to use a 5mm (or 7/32") L-shaped Allen wrench to push the metal shaft back out from the opposite side. That easily exposed enough of the threaded portion of the metal shaft to enable me to screw the red knob back on. It was nice to be able to do a 0-cost repair.
Old 10-22-2019, 11:10 PM
Still here
pmax's Avatar
Originally Posted by Undecided View Post
Amazing how much surface rust is on those just from sneezing at it !
Old 10-22-2019, 11:43 PM
Does anyone know the part number for the round flat head bolt? Mines rusted. Don't know weather to paint or replace.
Old 11-22-2023, 06:28 PM
anyone?
Old 11-25-2023, 07:45 PM
